New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      11-28-2015, 06:21 PM   #1
aznoo1
Drives: z4
Would these offset work on E89 z4 3.5i
19 inch 9.5 width 25et offset fronts
19 inch 10.5 width 26et offset rears
checked online im 4mm closer to the strut compare to OEM 296 and 22 mm further out.
Would this setup cause any problems
      11-29-2015, 02:55 PM   #2
jts1981
jts1981's Avatar
213
Drives: n54
Hit up Eric @ getyourwheels.com
He can help you.
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
      12-12-2015, 09:51 PM   #3
Squddie
Squddie's Avatar
Drives: E89 Z4
I would say it'll fit. I run mine with 245mm in front. While I don't have 9.5" wheels the tire should still be the deciding difference here. The struct is quite a bit off still.
zpost
