11-02-2015, 10:06 PM | #1 |
52
Rep 418
FS: work wheels lips
As the title says I have a set of Work wheels lips for sale with original box and paperwork proof. Waited 6 months for them. 19x5" step lips with mirror finish. I sealed them and put them on for test fit, then took them apart and scraped off the sealant and reboxed them. There may be a knick here or there as they were at a shop, and the black smudges are just leftover Dow832 sealant which I will throw in one tube to buyer and it'll seal all the wheels, with leftover sealant. My loss is your gain. I have no use for these anymore. I also have a set of 3" step lips and a set of 4.5" step lips that are both tapped for TPMS , but need to be refinished as they the original set I had on the wheels before rebuilding and have road minor dings and whatnot, but no rash or bending. Pics upon request and I'll sell the whole set of 4 for $450 shipped or each set of two for $300 shipped. |
11-09-2015, 12:46 PM | #3 |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
tempted... Question... Would I need an 18 inch face or 19 inch face to fit these, since they're step lip..
Also trying to figure out what the width would become in the end if I get the face. Trying to figure out the 3 piece build process.
11-09-2015, 01:14 PM | #4 | |
I got lei'd
844
Rep 7,593
I think 1" is 13mm, translates to +13 offset ?!?!?!?!?! |
11-09-2015, 01:15 PM | #5 |
2111
Rep 13,877
So, if I found a work wheel that I want to take the face from, it would have the be a flat lip 18" face, or 19" step lip, correct? Also, is this already 2 pieced? Or, is this one piece, and I need two other pieces one being the face)? And, damn! +13 offset!? I don't even want to inquire about the 5" lip then!
Yikes!
11-09-2015, 01:24 PM | #6 | |
I got lei'd
844
Rep 7,593
looks like it's only the outer barrels, you'd still need the inner barrels, that's what depending on the size ($200 per barrel) and those need to be drilled too for the bolts |
11-09-2015, 01:28 PM | #7 |
2111
Rep 13,877
Got it. Thanks. Might be more than what I'm looking to do. Seemed like a good deal for the outters, but probably will end up being similar prices than just buying used Brombachers.
11-09-2015, 05:55 PM | #8 | |
52
Rep 418
I also have a 3 inch set and a 4.5 set of lips that I'm trying to sell for cheap as they need to be refinished. they are also tapped for toms as well. |
