10-24-2015, 11:39 PM | #1 |
239
Rep 363
I own f10 2015 550xi (July 2015 production date) and my wife has f15 2015 x5 50 (September 2014 production date). Has anyone notices that, despite a very smooth power delivery, when you press the gas pedal from the dead stop, on X5 it is feels like the car jerks a little? This is complete opposite from my 550xi where it is smooth as I can possibly wish for.
When I installed BMS chip (12 oÂ’clock setting) into X5, this initial jerkiness became more pronounced. Also, when the temperature outside got a little cooler (60Â’s) and when we drive off in the morning, first few minutes the car stumbles from dead stop, almost like it will die (this was not happening without a tune). When I installed the BMS chip into my 550, there are no issues whatsoever. Has anyone experiences anything like that with or without tune? Thank you Last edited by ellisina4; 10-24-2015 at 11:55 PM.. |
10-25-2015, 01:17 AM | #3 |
45
Rep 173
This is one of the main reasons I'm debating spending the extra money for the Dinan. We had a e70 50i and my wife thinks our f15 stock is a lot more sensitive throttle wize. She describes it as jumpy. We've had cars chipped in the past that were like this and it made it worse.
10-25-2015, 02:23 AM | #4 |
92
Rep 208
I feel that in sport mode, which I use 90%+ of the time, that there seems to be a throttle delay. When in sport + mode, I feel power seems more immediate but the shifts aren't as pronounced.
I am awaiting my Bms tune, and hope it doesn't worsen throttle response and/or cause a stumble upon cold start. |
10-25-2015, 07:21 AM | #5 |
5453
Rep 8,815
I think the slight throttle response is normal from the N63TU. I noticed the same thing on my 550 and also on a 650GC loaner I had. It was the first thing I noticed when compared to my previous 535. The N55 while isn't nearly as powerful has instant throttle response (especially with MPPK).
10-25-2015, 08:27 AM | #6 |
3619
Rep 4,532
My 2016 50 has the same throttle delay in comfort mode pure stock no tune. Sport plus stops the delay.
Added BMS and it did not help or hurt the delay. Feels stock. Present in comfort, gone in S+. |
10-25-2015, 08:27 AM | #7 | |
239
Rep 363
I wonder if it is the DME software update as mine is 2015 model with 2014 build date. I will ping x5onfire who has 2016 model to chime in. He has been using BMS tune also. |
10-25-2015, 09:04 PM | #10 |
239
Rep 363
The following is the response I received from BMS:
"The Stage1 tune is just going to magnify the stock tuning a few PSI. So whatever problems exist with the factory tuning on the vehicle will still be there with the Stage1. There isn't much we can do for you on either issue you're having." Just an FYI. |
10-25-2015, 10:20 PM | #11 |
9
Rep 62
It's stock 50i with BMS. And I completely agree with the fact that it's not tune that causes this issue. To confirm it I uninstalled tune this morning and issues with "cold start engine bogging" still persist. Need to see dealer I guess.
BTW, I can recommend tune to anybody. It takes 2 minutes to install (30 seconds uninstall). And you definitely can feel extra torque. |
10-25-2015, 10:49 PM | #12 | |
239
Rep 363
The hesitation from dead stop was the one that got worse with the tune. |
10-26-2015, 06:59 AM | #13 | |
9
Rep 62
10-26-2015, 06:59 AM | #14 | |
478
Rep 1,363
10-26-2015, 07:48 AM | #15 | ||
239
Rep 363
On the other hand, I will call my stealership and check if there are any DME updates available for my VIN. |
10-26-2015, 09:04 AM | #16 | |
110
Rep 525
10-26-2015, 01:59 PM | #17 |
12971
Rep 18,717
Edit: Disregard, just remember different air filter setup on the F15/F16.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
10-26-2015, 07:22 PM | #18 |
9
Rep 62
I still don't think it's BMS tune. I've had tune since May and my car was perfect (no bogging/choking). It developed this habit last month. My guess it has something to do with cold weather/car problem(existing). Tune just can not go bad. It works right now and works perfectly. Those 500+ lb/ft of torque feeeeeeels very good.
10-27-2015, 08:47 AM | #19 | |
110
Rep 525
10-31-2015, 02:59 PM | #20 |
92
Rep 208
Bms tune installed today. Had a few launches, and boy what pinned to the seat torque w the power of that monster under the hood. Will give it some time and report back.
10-31-2015, 09:51 PM | #21 |
12971
Rep 18,717
@Bigb348 that must have been fun.
11-01-2015, 07:20 PM | #22 |
459
Rep 576
