10-06-2015, 04:11 PM | #1 |
11
Rep 130
Tire Rub + Suspension Setup
Hey guys, not sure if this is a suspension question or a tire question... OR BOTH!
I recently put 18x8.5 Style 264s w/ 245/35/18 Hankook Ventus V12 Evo2 tires on the front of my 2011 135i. Noticed there was a bit of rub on hard bumps and corners. Suspension set up is eibach pro kit, m3 control arms, m3 sway bar, and whiteline end links. I am not a suspension wizard, but my last alignment after the control arms went in was -1.9 camber in the front. I got my fenders rolled and there is still a bit of rub on hard corners and BIIIIIG bumps. Would Dinan camber plates resolve this? They add -0.7 camber. I cannot afford to throw coilovers on the car. Custom alignment? Does anyone have a similar setup? Thanks! PS yes, I know there was a 3 post thread on this like 2 years ago but the answer wasn't there. Edit: 12mm front spacers. Last edited by Funch; 10-06-2015 at 04:41 PM.. |
10-06-2015, 04:38 PM | #2 |
California-bound
385
Rep 1,480
How big are your front spacers?
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
10-06-2015, 04:40 PM | #5 |
11
Rep 130
10-06-2015, 04:42 PM | #6 |
California-bound
385
Rep 1,480
A bit more camber, or a more thorough fender roll will solve the problem. That fitment isn't that aggressive.
10-06-2015, 04:47 PM | #7 |
11
Rep 130
10-06-2015, 04:48 PM | #8 |
4338
Rep 6,196
10-06-2015, 04:49 PM | #9 |
11
Rep 130
10-06-2015, 05:12 PM | #10 |
125
Rep 750
Drives: '98 Z3M (gone), '09 135i
You can try with 10mm spacers and figure out exactly where it's rubbing and I bet they will fit, it will probably prevent everything but the really crazy bumps you get on the highway around here. The bumper tab and the sharp part of the fender is where mine was rubbing on hard bumps so i ground them down.
10-06-2015, 05:24 PM | #11 | |
11
Rep 130
10-06-2015, 05:52 PM | #12 |
4338
Rep 6,196
10-06-2015, 06:01 PM | #13 |
105
Rep 376
BMW Performance Springs, Dinan Camber Plates, M3 lower control arms, M3 front strut brace with strut tower slotted additional 1/4" with both strut brace rings touching strut tower hole lip, Apex ARC8 with MPS tires 235/40-18", Alignment with Max camber; Drivers
side -2.3*, passenger side -2.9*. Still have a slight wheel to bumper tab rub over large bumps that fully compress the spring. Have noticed many have less camber adjustment on the left than on the right. Local body shop owes me a favor so I'm going to see if they can massage the drivers fender to keep it from rubbing. It rarely rubs but I prefer never rubs.
ER CP, Forge DV, Wagner FMIC, PE, Maddad Mid, ER Sports OC, BMS OCC, RB Check Valve, AFE intake, Cobb AP3- Stage 1+ drive, BMW SS, PS Springs, Yellow Koni external, M3 Control Arms F & R, M3 Strut Brace, M3 Sub Bushing, Rouge Toe, Dinan Camber Plate and Rear Shock Mts., E93 M3 front sway bar, Mfactory Diff, Arc 8 PSS 235/40/18-265/35/18
10-06-2015, 06:28 PM | #14 |
105
Rep 376
Forgot to add that only rubs on drivers ( left ) side.
Alignment after M bit installed in Janurary; -2.2* left, -2.5* right. After slotting and alignment this week; -2.3* left, -2.9* right. Something about the left side that keeps camber a bit lower.
10-07-2015, 08:22 AM | #15 |
4338
Rep 6,196
Also, adding the M arms does not help clearance as it does not pull the top of the tire in, it pushes the bottom of the tire out, which can actually make it worse. You need to bring the top of the strut in by camber plate or slotting.
I am at 2.17 deg left and right, and no rubbing. |
10-07-2015, 11:33 AM | #16 | |
105
Rep 376
10-07-2015, 12:01 PM | #17 |
4338
Rep 6,196
10-07-2015, 02:11 PM | #18 | |
125
Rep 750
stock suspension, 18x8.5 264 type wheels 10mm spacers, 255/35/18 dunlop zII, camber mod, fenders pulled/roll. height matters for these tires because they run wide and if I were to do it again I'd probably opt for something 245 sized of this tire instead. Also, a stiffer setup will reduce the amount wheel movement. I've only had minor rub on big dips and potholes on the highway when i don't slow down from 80, I bet if I had a stiffer suspension setup it wouldn't have any issue even on the big dips. |
10-07-2015, 06:38 PM | #19 | |
105
Rep 376
want to do since there is a good possibility of adding noise. OP sounds like he has a budget and looking for max camber with Dinan Plates. Saying ride hight doesn't matter is like telling your girlfriend size doen't matter.
10-07-2015, 11:46 PM | #20 |
167
Rep 403
That'd be my recommendation as well.
I've a no-rub, no-fender-roll setup with 245/35-18 RE050RFT tires on 18x8.5" 264s up front. Full details at http://www.1addicts.com/forums/showthread.php?t=1170959 Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
10-08-2015, 10:25 AM | #21 |
4338
Rep 6,196
10-08-2015, 11:16 AM | #22 | |
11
Rep 130
