09-24-2015, 02:22 PM | #1 |
13
Rep 136
Save now fix later! S65 replacement parts
I parted out a few blown S65 and have a lot of key replacement parts most will need, I am selling them pretty cheap so it can save you money for when it happens. Alternator - $300obo Starter - $250 obo Lower oil pan - $500 Throttle body sets - $300 per set Connecting rods - $50 ea Pistons - $50 ea or $75 with the rod Crankshaft (has bearing wear) - best offer Cylinder heads - $1500 set Camshafts - $400 set Injectors - $150/set Idle actuator - $150 Valve covers - $200 set Cover for valve cover - $40 ea Cam sensors - $75 ea Oil cooler lines - $100 set Intake manifold - $200ea obo Belt pulleys - $25 ea Crank pulley - $50 Exhaust manifolds - $200set Secondary cats - $150 set Located in Toronto Canada but will ship at buyers expense, or split cost depending on deal. Need to make some space!! I also have the block with 2 holes in it, perfect for a custom table! I'd do it but have no space to put that...aka the wife thinks it stupid to have an engine as a table. |
10-02-2015, 10:36 AM | #6 |
13
Rep 136
