New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      09-02-2015, 10:43 AM   #1
Tangent
Drives: G01, F82, E89, F25
Z4 35i bucked twice this morning...
This morning right after a cold start my Z4 gave a quick buck twice (several seconds apart) when lightly accelerating in second gear. I don't have any long cranking when starting, but I do have what I think is a louder than usual whine from the fuel pump. I say "think" because even though it's noticeably louder than my E46, I also know the pump's likely a lot closer to me than in that car right? It is a bit of an odd uneven sound though, almost like morse code. It's been doing that since I bought the car 2 months ago and performance and starting has always been flawless until this morning. Am I looking at the HPFP failing or could this be something else?
      09-02-2015, 11:59 AM   #2
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
DCT?
I had that once or twice too when car was cold. Have it in my M3 too on occasion. I wouldn't be too worried unless it is repeatable or worsening
Using the "manual" mode seems to eliminate the issue
      09-02-2015, 01:50 PM   #3
Tangent
Nope, it's a manual. Hopefully it was just one of those of little hiccups modern cars have occasionally...
      09-11-2015, 10:08 AM   #4
Lurcher
Lurcher's Avatar
Drives: 2012 z4
all else fails, reboot....
Seriously, remove battery cables for 30 minutes and reset
      09-11-2015, 10:19 AM   #5
Tangent
Ha, yeah. "Hello, IT, have you tried turning it off and on again?" It did it once more this morning, but between my original post and now that's it.
      09-14-2015, 02:13 PM   #6
SpikeMilligan
35is driver
16
Drives: 2012 S-drive 35is
Fuel pump?
Instead of the fuel pump, it could also be a clogged fuel injector (damn ethanol fuel!). A bottle of injector cleaner in the gas tank may be able to clear it up if it's not too clogged.
I had similar hesitations, which later turned into long cranks, and eventually threw some misfire codes, so BMW replaced all the injectors. Thankfully under warranty.
zpost
