08-29-2015, 08:21 PM | #1 |
X3M Comp
444
Rep 718
Service Questions/Concerns..Backing Plate
My 2015 F80 was scheduled for a service this weekend and I took it to my local dealer. A little history of the car prior to service. I just recently installed the OBDII CAN Module for the car and absolutely loved how it transformed the sound of the car.
I had the controller on for about a week or so and out of the blue I got a check engine light. I assumed it must be something with the valves so I was able to reset it using the feature built into the module. I figured the error would be stored on the Cars computer and I could ask my SA to look into it. When I got my car back this is what they addressed: 1. The vehicle test showed code 102001. As per the SA the check engine light was a result "LOOSE EVAP PURGE VALVE HOSE DIAG CODE D1160_B00000000_17_305" This was addressed by resecuring the hose and a reset of adaptation values. 2. The other thing that was out of the standard service was that when my car was road tested they heard the scraping sound (which we have all heard before) from the rear brakes. I have always assumed it was rock or debris caught in there which would find its way out. In this instance the following was done, "REFERENCED SI B34 06 15 TO REPLACE BACKING PLATES WITH REDESIGNED PART. REMOVED BOTH REAR WHEELS AND HUBS AND REPLACED BOTH BACKING PLATES." 3. I also mentioned the squeaky doors and that there was a service bulletin regarding this. My dealer was not able to locate any such bulletin. However they did replicate the sound and said it was caused by wax buildup. They cleaned the seals and sound is definitely better. Any thoughts |
08-29-2015, 08:35 PM | #2 |
220
Rep 433
Thanks for posting, I heard about #2 but interested to know more about #1 if anyone else has had this problem
______________________________
?05 E46 M3 ZCP 6MT ?06 C55 AMG '97 911S 6MT |
08-30-2015, 12:22 AM | #3 |
749
Rep 2,108
Thanks for posting the SIB
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs Last edited by BuLoOoSki; 09-01-2015 at 03:27 PM.. |
