New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      08-27-2015, 12:53 PM   #1
bimmer_yu
Drives: BMW F10 520d + BMW E89 35i
BMW - screen removal
Hello,
Like my BMW Z4 35i but recently I noticed some issues with CIC screen. Everything works perfectly appart from there were some scratches and screen become squeeky when opens and closes.
I tried to fix scratches by using Novus plastic polisher and I am very happy with the results but it's impossible to get to the corners properly without damaging the frame... Basically I removed anti-clare coating (not a big deal even at sunlight) but couldn't reach to the corners. In oder to do a proper job here I feel like I need to remove the screen, dissasemble it and then finish with Novus and seal everything with non-glare screen protector.
I mean I already did all that, results are excelent but as I couldnt reach corners screen protector doesnt stick in the corners properly. At the same time I want to put some silicone lubricant in order to fix sqeeky screen...
To make long story shorter - how to remove screen and dissasemble it?
      08-30-2015, 01:59 AM   #2
bimmer_yu
Managed to do it. Its not that complicated.
These are the steps:
Remove trim, remove front vents, remove front speaker grill -> you get access to the 4 screws that hold screen in place.
Screen is Sharp LQ088K9LA02 and its replaceable. I did mine with low-speed Dremel and put custom-cut AG screen protector over it.
A lot of dust, insects etc got into folding mechanism. Afrer cleaning it and lube it with silicone its not sqeeky anymore.
      06-16-2020, 02:57 AM   #3
LOKSIM
Drives: 520D, X5, Z4 E89
Replacing Z4 E89 LCD screen
Hi, My Z4 is 2.3i the LCD screen protective layer crack, need to change, which is the model LQ088K9LA01/02 suitable ? appreciate your advice
zpost
