M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Regional Forums > UK
      08-20-2015, 08:59 AM   #1
2012F10M5
United Kingdom
Drives: BMW M5 Monte Carlo
Air Conditioning
Hi
Has anyone had their Air Conditioning Condenser replaced? Mine is due in on Tuesday, BMW are footing the bill (it seems to be an issue on this model) but they are saying I will need to pay for a re-gas (£160+). Surely if its FOC they are admitting its a BMW problem, and it only needs a re-gas as the condenser is leaking.
Anyone had the same issue?
Thanks
      08-23-2015, 05:32 PM   #2
87ja
Scotland
Drives: Bmw M5 Monte Carlo Blue
Originally Posted by 2012F10M5 View Post
Hi
Thanks
I had my M5 into Douglas park bmw Glasgow on Friday with the exact same problem.
They advised me that I would have to pay a diagnostic check to figure out weather it was just a re gas or not. After figuring out it was the condenser they have said it will be a full warranty claim and wouldn't cost me a thing.
If I was u I would complain as u wouldn't need a re gas if it wasent faulty.
      08-23-2015, 05:38 PM   #3
87ja
Scotland
Hi
Thanks
      08-24-2015, 04:11 PM   #4
Mark6147
England
10
Drives: F90 M5
I am the same. They diagnosed a faulty condenser and replaced it under warranty.
Still not convinced car is cold enough though!
      08-24-2015, 06:19 PM   #5
iamvietness
Drives: 2015 M3
Mine will be going in Wednesday for the same. It was blowing hot air on the driver side and cold air on the passenger...not fun for the 100+ degrees we have right now
      08-24-2015, 07:55 PM   #6
v3n0m
57
Drives: 2013 MCB M5
Did you check the dials immediately beside the lock/emergency light buttons? Same thing happened to me and I had them set to 'red'.
      08-24-2015, 11:21 PM   #7
iamvietness
Drives: 2015 M3
yeah i did
      08-26-2015, 08:12 AM   #8
aszcpl7
Lithuania
Drives: F10 535xi
It cant due to mixer setting to red. Evaporators are faulty from factory. Our customer had this issue too, and was told by dealer that it's indeptended of his playing with AC setting.
      11-09-2015, 11:00 AM   #9
snickjam
Drives: 2012 F10 M5, 1993 850Csi
I think I may have to, as my air conditioning has failed, possibly condenser, hasn't been in to dealer yet as out of warranty (2012 F10 M5)
      11-09-2015, 11:02 AM   #10
snickjam
Further to last post, does anyone know the location of the condenser?
      07-15-2016, 12:56 PM   #11
lanab
39
Drives: M5 F10 MY12
I have a M5 MY12 with the same problems condenser leaking and installed a new one this week, however i noticed the new one was leaking as well which freaked me out.
I have found the source of the leak and it was leaking from the plastic torx plug at the bottom of the dryer which is accessible from underneath the engine if you remove the plastic underbody protection.
I could see there was some fluid around the plastic plug so i tried tighten it carefully and found out the plug was hand tight only, i tightened it and now it's not leaking.
This is a obvious QC problem from the Hella/Behr factory in France, they should have tightened to the right torque from the beginning.
      07-24-2016, 07:31 PM   #12
spenny_b
United Kingdom
13
Drives: 2020 M2 Comp, HS
Had my condenser replaced on Friday...usual thing, blowing ambient temp air. No charge to me for diag, fitting or re-gassing. Per above comment, still not ice-cold..but then my previous 1-series wasn't either...cold enough, but not as chilly as a previous Golf GTD....I know that R134 isn't as good a refrigerant as previous gas, but 134 has been around for many years now.
@Ianab- if your condenser was still leaking, you'd have lost the gas, not expelling water. You'd also be able to spot gas leak with a UV lamp, they re-gas with a green/yellow dye. What you're spotting on the ground sounds like the normal expulsion of water from the AC system (ie, are you sure you should have tightened whatever you tightened? You may have inadvertently created a moisture trap?)
