08-16-2015, 03:33 PM | #1 |
155
Rep 1,400
Stock Exhaust Valve Mod different sounds
Has anyone noticed the stock exhaust with the valve mode sounds different in sport then sport +? I would like to find out why. It's more metallic specially at high rpms in sport.
08-17-2015, 10:02 AM | #3 |
346
Rep 366
Hmm. I have stock exhaust and use the Burger can flap. When set to open (which should basically be the same as the valve mod), I can't say that I've noticed a difference in sound between sport and sport+ and I do switch back and forth quite a bit.
Scott |
08-17-2015, 10:32 AM | #4 |
91
Rep 258
Odd you post this, because a few days ago, I decided to not run everything in sports+. I went with sport and D3. And when I drove off it sounded very different, as in deeper. Once I noticed it I than floored it a few times from a stop and rasp wasn't really there at all. I have 10k miles on my exhaust and it's fully stock with the flap mod controller.
08-17-2015, 11:32 AM | #5 | |
155
Rep 1,400
08-17-2015, 12:53 PM | #6 |
118
Rep 287
I read somewhere that the valves in sport and sport+ are not fully open the whole time .. with the valve mode they just all the time 100% open which I guess makes the diffrence.
08-17-2015, 05:30 PM | #8 | |
1683
Rep 1,812
Drives: 2015 6MT YMB M3, 1974 Corvette
Scott, I was looking at the BMS OBDII Can flap module. Is this the one you are running? How do you like it? Was it hard to install/configure? Where do you tuck all that cable away (so to speak)? Can you take a picture of it - how it looks installed on the OBD port? Thanks!
AIRPOWER
08-18-2015, 06:13 AM | #9 | |
346
Rep 366
Ridiculously easy to install. Took maybe 2 min, if that--just plug it in and tuck in the cable. It's really easy to hide the wire on the run back to the seat. Will try and take a picture later today and post or PM it to you. Scott |
08-18-2015, 06:22 AM | #10 | |
1683
Rep 1,812
Thanks so much for the prompt reply! When you say hide the wire on the run back to the seat does this mean along the door sill? Can it be tucked under the dash? Looking forward to the picture(s).
AIRPOWER
08-18-2015, 02:50 PM | #11 | |
346
Rep 366
Not sure about tucking up under the dash. Seems possible, but don't know for sure without dropping the lower dash panel to see how much room is up there for the extra wire plus the controller box. |
08-18-2015, 08:42 PM | #12 | |
1683
Rep 1,812
Again Thanks for the pics, I think I am definitely ordering this!
AIRPOWER
08-19-2015, 10:11 AM | #13 | |
21121
Rep 20,741
Drives: 2021 911 turbo
Two things come to mind: ASD and waste-gates.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
