New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      07-09-2015, 09:36 PM   #1
JDB30
Drives: 2010 Z4 sDrive 35i
Grinding Noise with Nav Screen
Hi,
My Nav Screen has developed a grinding noise when it opens and closes. Has anyone else had this issue?
Dealer said it would cost $3,000 to replace the motor that opens/closes the screen. That seems insane.
Looking for any guidance available from you kind folk.
Thanks.
      07-10-2015, 02:57 PM   #2
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
Common issue. No known solution afaik.
      07-10-2015, 03:23 PM   #3
VailM3
61
Drives: 2011 Z4 35is
mine has this grinding sound too but 3k seems insane...i hope it just doesn't break 1 day.
      07-10-2015, 07:34 PM   #4
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
WD40?
leave it open?
      07-12-2015, 02:29 AM   #5
Asbjorn
Asbjorn's Avatar
China
90
WD40 is not a lubricant. It is suitable for removing stickers, tar and loosing rusty bolts etc. Anyway, I wouldnt spray anything back there without knowing what I was aiming at. I assume the noise is there due to dust and dirt accummulating over time somewhere inside. It is a convertible after all. WD40 attracts dust so I wouldnt use that.
      07-12-2015, 09:16 AM   #6
jparnes1
jparnes1's Avatar
245
Drives: 2016 340i, 2012 Z4 35i
Try a dry lube spray like s Teflon spray. Goes on wet, dried to a powder in seconds.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      07-12-2015, 09:31 PM   #7
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Originally Posted by Asbjorn View Post
WD40 is not a lubricant. .
Didn't realize that. I have been using it to lubricate (home) hinges and door locks for some time
      07-13-2015, 02:49 PM   #8
bigendbob
United Kingdom
50
Drives: z4 23i Orion Silver
WD40 is basically a water dispersant. Similar to a petrol and light oil mixture.
Wouldn't like to spray it on plastic.
If you look at the gap to the right of the display you will see the gears.
I sprayed some silicon on there when it rattled.
In fact every joint in the car gets a dose regularly.
Of course you have got to ask yourself who would have designed this screen with exposed gears?
Why are they not sealed away inside the unit clear of any potential dust or grit falling on the gears. Especially with an open top car.
Their solution seems to be, to have large clearances around the gear teeth, so the whole lot rattles.
      07-13-2015, 06:08 PM   #9
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Doesn't silicon eat away at rubber? Not sure if that's what you meant by "joint" but, my understanding is that silicon on rubber things (like the door/window seals on a 3 series) is not a great idea because it will cause issues in the long run
      07-14-2015, 04:35 PM   #10
bigendbob
United Kingdom
50
Not that I have seen in 3 years.
In fact the seals don't feel like rubber, more like some kind of recycled plastic.
zpost
