New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      07-08-2015, 12:24 PM   #1
keithro
Drives: 2011 Sdrive35is
Dash trim removal
Anyone know of a write up or how to remove the dash/door/console trim pieces? I'm planning on painting the pieces body colored.
      07-09-2015, 04:10 PM   #2
Desmo85
Desmo85's Avatar
83
Drives: E60 / E87 / E89
Dash is quite easy:
-Pull out ignition key cover (first pic)
-Pull out Radio Cover (second pic)
-Pull out Passenger Dash side cover (third pic)
-Unscrew all Torx Screws
-Gently pull the dash out
-Unplug the Ignition and the Climate Control
(Can someone translate into english? Found these pics some time ago cant remember where)
      07-09-2015, 04:54 PM   #3
bigendbob
United Kingdom
50
Drives: z4 23i Orion Silver
That's interesting.
Never known a car with so many rattles behind the dash.
      07-10-2015, 11:25 AM   #4
keithro
Thanks, that's perfect! Anyone have anything on the trim panels on the doors or the small one on the drivers side of the steering wheel?
      07-13-2015, 05:53 PM   #5
Tangent
Drives: G01, F82, E89, F25
Originally Posted by Desmo85 View Post
(Can someone translate into english? ...
"Remove screws"
      07-14-2015, 12:57 PM   #6
rking117
Drives: Z4 3.0i & 320i
Originally Posted by Tangent View Post
"Remove screws"
literally translated to English it is loosen a screw but remove screws is the better translation.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      08-14-2015, 03:03 PM   #7
keithro
Anyone know how to pull the other trim pieces and the door handle surrounds?
      11-15-2015, 07:19 AM   #8
pavproch
9
Drives: Z4 3.0i & 330ixT
Well, a centre console trim as well as both dash trims swapped to "Alu Carbon" (btw, thanks for the pictorial above ) but it came to no ends with the door trims .... loosened the torx underneath the door handle, pried loose its forward end, but cannot figure the way how to pry the rest of it.
Anyone knows "how to"?
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      12-14-2015, 11:03 PM   #9
azure82
Drives: z4 e89
You can use following video clip.
However passenger door is little bit different. You have to pry off door handle and there will be 2 torx screws.
(Don't know how to put video on thread.)
https://www.youtube.com/embed/TJ3FkjeL9TE
      12-20-2015, 04:23 PM   #10
Squddie
Squddie's Avatar
Drives: E89 Z4
Hey that looks easier than accessing the fuses in the E89
(for those not in the know, this is not a joke)
      05-13-2016, 09:33 AM   #11
keithro
Were you ever able to get the door panel trim pieces swapped out? Also, how does the trim piece to the left of the steering wheel come out? Does that one just pull out?
      03-05-2017, 06:22 PM   #12
jake169
29
Drives: 2011 35is
I was able to take the door trim out today. All you have to do is keep prying with the trim removal tool. There are very tine clips towards the end and will not survive the removal. The major clips are still intact so should be fine.
      03-19-2017, 01:30 AM   #13
cruisingdownthestreet
123
Drives: Z4
are these enough to remove the trim?
they're too chubby to fit through the gaps of the radio (battery for scale)
      05-08-2017, 01:15 PM   #14
tumnus
Drives: Z4 E89 S23i
If you have the extended leather option do not follow the instructions above, or you will end up with a broken ignition key cover!
- Start by removing the centre console as per the instructions above.
- Then remove the plastic fascia underneath the head unit, it will pull free.
- There are two screws holding in the head unit, undo these and lower the head unit out of it's frame, this is covering two of the screws for the large dash trim.
- Remove the remaining screws in the glove box, once all of the screws are out you should be able to remove the trim with a trim removal tool.
- Remove the trim with the light controls with a trim removal tool, there are no screws for this piece.
      11-25-2022, 11:16 AM   #15
Helirupert
Drives: BMW Z3M Roadster & E89 Z4 35is
There are two versions of the ignition key cover with different appearances: One is with clips and screws. Just identify your version from the picture in the link below.
https://www.realoem.com/bmw/enUS/sho...diagId=41_2991
zpost
