06-22-2015, 04:17 PM | #1 |
Captain Fatbelly
1423
Rep 1,994
Rod Bolts
So my car goes under the knife next month to have the bearings replaced. I'm going with the wpc treated bearings but am undecided on which bolts to use. The shop doing the work suggests the arps, but some very smart people on here have said to stay with stock. Not worried about the stretching process necessary with the stockers, just want the best in terms of longevity. Anyone have any input?
Thanks
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
06-22-2015, 06:25 PM | #5 |
750
Rep 4,430
Subscribed
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
06-22-2015, 06:26 PM | #6 |
140
Rep 1,665
06-22-2015, 08:11 PM | #8 |
5260
Rep 10,640
06-22-2015, 09:17 PM | #11 | |
Captain Fatbelly
1423
Rep 1,994
And does anyone know for sure if the bearing kit at bimmerworld are wpc treated? They say treated but not specifically wpc.... |
06-22-2015, 09:18 PM | #12 |
Captain Fatbelly
1423
Rep 1,994
A shop in your neck of the woods, european road and race.....I think. Going to talk to a few places in Charlotte before committing but I'm leaning towards them.
06-22-2015, 11:38 PM | #13 |
Retired Curmudgeon
2985
Rep 4,049
Jackass much?
OP -- stock or if you have to have something else have your shop call Lang and discuss their thoughts on rod bolts.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
06-23-2015, 12:42 AM | #14 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Use the OEM bolts they are the bolts the rods were made to use. If you were doing a full rebuild and could remove and hone the rods you could use the ARP's with no issue, but since you aren't there is only one choice.
06-23-2015, 12:43 AM | #15 | |
427
Rep 1,947
06-23-2015, 02:21 AM | #16 |
140
Rep 1,665
If lang said 5ft/lbs was ok and there was no bore distortion half the people on here would believe it and recommend it to others when they have no idea at all
06-23-2015, 06:04 AM | #17 |
5260
Rep 10,640
06-23-2015, 06:32 AM | #18 |
140
Rep 1,665
And thats fair enough but in saying that you must also go against carrillo for there own rod bolts that they have worked out what ft/lbs clamps the cap to the rod best for each materials
06-23-2015, 07:48 AM | #19 |
5260
Rep 10,640
I am not sure Lang was going against Carillo. If you read Lang's post on the subject, you will see that Lang stayed within Carillo's stretch spec. I have not read Carillo's instructions for bolts for these motors, but I have read ARPs, and ARP prefers the stretch spec to the torque spec. ARP also says that the stock rods should be resized when using ARP bolts. No one doing a bearing swap resizes the rods since they do not remove the rods. Based on all this, I would be most comfortable going with what a racing shop with experience building these motors has found to work based on actually testing of the bolts in rods on the bench using both the stretch and torque spec. If Lang has found 50 lbs gives the least distortion, that is what I would go with. I would not be surprised if Carillo revises its torque spec to Lang's torque spec.
07-02-2015, 03:54 PM | #21 |
Captain Fatbelly
1423
Rep 1,994
So are the Carrillo's a good choice as an alternative to stock? No bore distortion, more clamping force and an easier install?
07-02-2015, 09:11 PM | #22 | |
Grease Monkey
295
Rep 2,646
Id stick with the OEM hardware if I were you. |
