New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      06-15-2015, 04:59 AM   #1
BIGBOYQ
BIGBOYQ's Avatar
United Kingdom
37
Drives: Z4 28i
Help: routing cable into engine bay
Hi,
I want to route an cable into the engine bay, but unable to find an route - anyone done this?
Taken cover below glove box when replacing an blown fuse, but unable to find an route into the engine bay.
What I am trying ot achieve is to get power via USB or Cig lighter to my JB4 Connect Kit.
So I have two options:
1) Power the JB4Connect Kit via an internal source, so route an USB cable from the cabin into the engine bay
2) Power the JB4Connect Kit via an source from the engine bay (USB or CIG)
http://jb4connectkit.com/store/index...&product_id=50
Below is an video from an E92
[u2b]https://www.youtube.com/watch?v=VypGDrUtvks&noredirect=1[/u2b]
Help very much appreciated, as routing the cable via the door - is causing an puddle every time it rains!
E89 28i (14)
e92 335i (sold)
e46 330D (Sold)
e46 220D (Sold)
      06-15-2015, 07:54 AM   #2
Lurcher
Lurcher's Avatar
Drives: 2012 z4
why not use lighter socket in passengers foot well?
ahh nevermind - see the issue....
      06-15-2015, 09:01 AM   #3
rking117
Drives: Z4 3.0i & 320i
why cant you grab +5v DC from under the hood? I suspect that you might be making this more complicated than it needs to be. I actually pulled a trigger off my halos once to power some leds only when the vehicle was on. I used a voltage sensing relay that triggered a separate +5v to the leds when the halos were on. I wouldn't go with this approach for this application but you could tap into some other switched power source under there.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      06-15-2015, 10:19 AM   #4
wmandra
Track Addict
wmandra's Avatar
99
Drives: 2010 328i, 2014 Z4
When I had a JB4 in mine I installed the Connect Kit in the glove box getting USB power from the port that is in there. To get a wire from the engine bay to the glove box, open the electronics box cover on the drivers side of the engine bay (the harness from the DME routes into this box) and you can easily send a wire into the drivers footwell.
-b
Driver, Ratchet Head Racing #93 BMW Z4
Club Organizer, Garden State Euros Motorsport Division
2014 Glacier Silver Z4 28i M Sport - See the build thread: http://e89.zpost.com/forums/showthread.php?t=950367
      06-15-2015, 10:54 AM   #5
BIGBOYQ
BIGBOYQ's Avatar
United Kingdom
37
Drives: Z4 28i
-b
So there is an rout from the ECU Box into the foot-well?
As currently I have the JB4 inside the ECU case.
E89 28i (14)
e92 335i (sold)
e46 330D (Sold)
e46 220D (Sold)
      06-21-2015, 01:18 PM   #6
BIGBOYQ
BIGBOYQ's Avatar
United Kingdom
37
Drives: Z4 28i
FIXED
Hi,
Found the channel, much easier with good daylight - routed cable from DMU into glove box!!!
To be honest feel an bit stupid but I am
E89 28i (14)
e92 335i (sold)
e46 330D (Sold)
e46 220D (Sold)
      06-27-2015, 10:49 AM   #7
Dejablue
Dejablue's Avatar
Drives: 2011 Z4 SDrive 35is
Please help!
I am trying to route a power cord into the drivers footwell like you say, but after I removed the cover of the box on the drivers side under the hood, I don't see any way to easily send a cable through.
Am I missing something?
      07-10-2015, 08:20 AM   #8
BIGBOYQ
BIGBOYQ's Avatar
United Kingdom
37
Drives: Z4 28i
Hi,
I routed power from the USB socket under the central arm rest-
And feeded under the rubber in the door sill - or clip it under the plastic trim on the transmission channel
E89 28i (14)
e92 335i (sold)
e46 330D (Sold)
e46 220D (Sold)
zpost
