05-31-2015, 11:30 AM | #1 |
Captain Fatbelly
1423
Rep 1,994
Differential fluid question
Hi all, I just drained and refilled my diff but I'm a little concerned as everything I've read says it takes 2.5 QTS to fill, however at 1.5 QTS the fluid started coming back out of the fill hole. Normal? 2008 m3 dct.
Thanks |
05-31-2015, 12:10 PM | #2 | |
104
Rep 935
http://www.amsoil.com/mygarage/Vehic...=2008+BMW+M3+N |
05-31-2015, 12:17 PM | #3 | |
569
Rep 3,742
06-01-2015, 04:46 PM | #5 |
Captain Fatbelly
1423
Rep 1,994
So after switching over to redline 75w140 (not ns) I now have a grind/clunk come from the lsd when I make a tight right turn. Never heard it before switching the fluids. Guess I need to go back to stock oil?
Thanks |
06-01-2015, 05:19 PM | #6 |
341
Rep 947
Try draining some fluid and replace it with a FM, friction modifier. From the same brand. You guys need to use the SAF-XJ with FM in our cars.
06-02-2015, 09:16 AM | #7 | |
73
Rep 527
Drives: 2011 E82 135i, 2015 F15 X5 35D
06-02-2015, 10:13 AM | #8 |
62
Rep 122
Same here, Same oil, same noise. There are a few threads on the subject. From what I understand the noise is just a nuisance and not an indication of anything wrong - just tight clutches (at least that's what I'm telling myself). I personally skipped the friction modifier.
06-02-2015, 01:04 PM | #10 | |
73
Rep 527
I purchased the diff oil with the friction modifier from BMW but I have yet to install it to see if it remedies the problem. |
06-02-2015, 06:35 PM | #11 |
Captain Fatbelly
1423
Rep 1,994
So is this as easy as adding an ounce or two of fm or is this fluid just not what we need to be running? I've got the fm on order but don't mind switching back over to stock or going rp if that's a better bet.
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
06-03-2015, 06:56 AM | #12 |
335
Rep 4,633
Make sure when you fill, once the fluid starts coming out the fill hole to let it to continue to come out until it stops, or you will be over filling and it might leak out from the seals... The fluid is suppose to be level with the fill hole, not seeping out like most think..
+1 with fluid with FM in it
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
06-04-2015, 03:59 PM | #13 | |
Captain Fatbelly
1423
Rep 1,994
06-04-2015, 04:46 PM | #14 | |
Retired Curmudgeon
2985
Rep 4,049
Worse case is you'll spit a bit of fluid out the vent, but even on when I raced that was very, very rare. So, once the fluid starts running back out, pull your hose out and put the plug in and torque to spec. Don't sweat having an ounce or two too much fluid in there.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
06-05-2015, 10:56 PM | #16 | |
335
Rep 4,633
06-06-2015, 09:10 PM | #17 | |
Retired Curmudgeon
2985
Rep 4,049
Interesting info nevertheless.
