04-18-2015, 09:24 AM | #1 |
16
Rep 566
Secondary Cat failure - Rattle
One of my secondary cats are rattling like a little b*tch!
Had the 1er on the lift and pinpointed out that the rattle was from INSIDE one of the secondary cats. Never have heard / read about this issue before on here or e90post. However, a quick google search indicates that this is a textbook symptom when a cat fails. The ceramic inside is being knocked around. I've been running catless DP, with stock n54 mids (with secondary cats), and PE (with y-pipe) for 50,000+ kms. It seems that my fuel economy has been slightly effected as well. It's consuming slightly more fuel. Just wondering if anyone else went through a similar situation? Before this happened, I've been very happy with my exhaust setup. Now I'm forced with either a) purchase n55 midpipe b) simply straight pipe it (and if so, I'm debating between t304 vs t409 stainless steel to be tig welded on) Also, does anyone have the following exhaust setup? I've wondering if it will be too loud or create a drone: Catless DP + no secondary cats + y-pipe + PE. |
04-18-2015, 10:35 AM | #2 |
Chief Warrant Officer
1025
Rep 1,638
I'm close to that setup except I still have stock DP. My setup is loud on cold start and my GF finds it a little obnoxious, but I love it. I've heard that taking that setup to a full catless setup creates rasp and you'd want resonators.
But that is second hand info.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
