04-16-2015, 08:15 PM | #1 |
Joint Chiefs of Staff
4922
Rep 115,999
Some upcoming JB4 features!!
Saw these mentioned and wanted to make sure all the JB4 users here were able to stay up to speed. BMS is working on a new OBDII harness for the JB4 to eliminate the need to add the much maligned POSI-TAPs. This new double sided OBDII connector will be available for around $15 and and will connect to the JB4 harness making for a fully reversible setup with no tiny pin holes required in CANbus wires. Added bonus: the new OBDII connection point allows some new features. In dash gauges, on the fly map changes like the old E series JB4, on the fly boost by gear adjustment, MAX BRIGHT mode for LEDs, active sound mute, and that sort of stuff. It pokes from through a preexisting hole in the firewall for a nice and stealthy setup. BMS expects to have these ready in 2-3 months in high volume (its a custom mold, etc), and they can be retrofit to any JB4 kit. If you prefer the current tap location you keep it and if you want the new one and features then you add it.
Also in the works is a new fully billet weather proof enclosure so you no longer need to hide your JB4 under the plastic covers to keep it dry. Unless you want too. This is just the first prototype being tested now but final version will be anodized black. |
04-16-2015, 08:30 PM | #2 |
216
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
Looks promising man. Case is a good idea for those who like to wash out the bay.
LIVE FAST..DRIVE FASTER!! |
04-16-2015, 08:40 PM | #3 |
669
Rep 7,148
love to see a good product get better!
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen> 2007 BMW E92 335i Jet Black/Jade Grey <sold> |
04-16-2015, 08:45 PM | #4 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Can't wait for this!!
04-16-2015, 08:45 PM | #5 |
137
Rep 1,475
Drives: 🚀
Garage List 2015 BMW M4 [0.00]
2012 BMW 335IS (SOLD) [6.84] 2011 BMW 335XI (SOLD) [4.66] 2008 BMW 335xi (SOLD) [10.00] |
2008 335xi E90 - Sold - > 2011 335xi E90 - Sold - > 2012 335IS E92 Crimson Red - SOLD > 2015 M4 Yas Marina Blue SOLD> 2019 McLaren 570s SOLD 2015 Lamborghini Huracan
04-16-2015, 09:29 PM | #7 |
21
Rep 270
These parts look really good. Mike if I install stage 1 I don't need to use the POSI-TAPS, correct? I would rather wait for this to then install the the stage 2. Is it possible?
04-16-2015, 09:40 PM | #9 |
Gone Fishin’
7318
Rep 12,125
Because people are a lot more likely to plug in some cables than remove their ecu and ship it off for a bench flash.
04-16-2015, 09:41 PM | #10 | |
4922
Rep 115,999
Mike |
04-16-2015, 09:42 PM | #11 | |
4922
Rep 115,999
Mike |
04-16-2015, 11:33 PM | #12 |
17
Rep 42
So will the billet case work for existing JB4 owners? Just received my JB4 today (THANKS MIKE) have it on stage 1. Just took it for a spin the gain is very impressive no traction until midway through 3rd now!
Not sure adding more power than this without limiting boost per gear will make the car any faster since the car is now traction challenged! |
04-16-2015, 11:45 PM | #13 | |
87
Rep 286
A COBB can do a few of those things but not most and COBB has no plans to support this car anyway. Once you run into the limit of the JB4 (which 95% of users won't get close)for fuel and timing control you can do a simple backend flash and open even more doors. The guys that sell flash will try to down play "piggy backs" which the lower end ones that others sell have the draw backs of a flash and a piggy back while JB4 is a whole different game. If you just want to set it and forget it a flash might be the best fit but you lose a ton of flexablity. |
04-17-2015, 07:21 AM | #20 | |
4922
Rep 115,999
There is no putting a hole in the firewall as there is one there already. The wires are routed through that existing hole. Mike |
04-17-2015, 07:22 AM | #21 |
4922
Rep 115,999
04-17-2015, 09:39 AM | #22 | |
4922
Rep 115,999
Mike |
