03-30-2015, 03:42 PM | #1 |
658
Rep 1,749
sport display reading 480hp with tune
With ess linear piggy and 100 octane my sport guage on I drive hits 480 which is max of the display. This must be some way measuring power as otherwise if it simply used tables of rpm and throttle it wouldn't go above stock 40hp
Thoughts on how it calculates? |
03-30-2015, 03:52 PM | #2 |
21122
Rep 20,741
Drives: 2021 911 turbo
As I posted in the other thread, my impression is that it approximates power and torque based on the same parameters the ECU uses to establish how much fuel is sent to the engine.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-30-2015, 03:53 PM | #3 |
77
Rep 966
If anything like n54 tuning it targets load. The n54 load tales have some headroom. Then I would imagine load is then mapped to torque and HP in the idrive.
A piggy won't be as sophisticated as a map but this is a good intro on what both are essentially trying to achieve albeit by different means. http://accessecu.com/cobbtuningweb/s...lpFile_BMW.pdf |
03-30-2015, 07:06 PM | #5 | |
21122
Rep 20,741
Load (or torque output) is mostly dependent on mass air flow and RPM, the same parameters used to establish fuel injection requirements .
03-30-2015, 08:10 PM | #6 | |
2634
Rep 2,809
Honest question: Have you ever tuned before? From an ECU's lookup prospective, LOAD is calculated using various inputs (I.e. Throttle Angle, RPM, MAF, MAP, IAT....etc.). Fuel, Ignition and target boost tables are all dependant on the ECU's calculation of LOAD for lookup in each respective table. The ECU could easily extrapolate its calculated LOAD value against fictitious torque and HP values in another table and spit those values out in the Sports Meter. Furthermore, fuel and ignition tables ALWAYS have target LOAD overshoot protection. These tables are simply setup beyond normal target LOADs. If the engines overboosts for whatever reason, the ECU can handle this and knows what ignition and fueling should be for said calculated LOAD. It is not far fetched for the Sports Gauges to be able to continue extrapolating "torque and HP" past the regular target LOAD values. |
03-30-2015, 08:23 PM | #7 | |
21122
Rep 20,741
This is certainly not my area of expertise. I am open to be educated on the topic
Further, I am guessing that the calculated "actual" load values are used for the Sport Display as opposed to the "target" load values. I struggle to understand this sentence though: I guess you mean it the other way around, where the ECU estimates the power and torque output to be displayed based on the calculated actual "load".
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-30-2015 at 08:35 PM.. |
03-30-2015, 08:38 PM | #8 | |
2634
Rep 2,809
As for the last part of your reply, I mean it just how I'm saying it. The ECU is estimating power/torque from calculated LOAD, the same calculated LOAD the ECU is using to lookup fueling and ignition table values. Hope this makes more sense. |
03-30-2015, 08:51 PM | #9 | ||
21122
Rep 20,741
BTW, I am not trying to argue, I just want to understand. Quote:
And isn't this exactly what I wrote in the second post of this thread .
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-30-2015 at 09:20 PM.. |
03-30-2015, 10:28 PM | #10 |
658
Rep 1,749
The point of what I learned today is the power display is much more than a simple gimmick that references a preset #based on rpm and throttle input. It's clearly reading a,tune and possibly higher octane. I will turn tune off and with just 100 octane see what power I hit to compare.
Other lesson is no piggy back is undetectable in the least. Clearly the ecu reads and sees the added load or flow or whatever parameter, and spits out a higher than stock power figure. Buyers beware and tune at own risk. It was nice to see power pegged at 480 knowing that was the max reading of the guage and that it was likely putting out a lot more. Ess dyno shows 460 who for linear tune. |
03-31-2015, 01:10 PM | #11 |
1253
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
FYI I can get to 480 hp stock on the sport display
03-31-2015, 03:42 PM | #13 | |
1253
Rep 3,688
