      03-30-2015, 02:52 AM   #1
psamtik
Involuntarily BMW
31
Drives: 09 E82 135i
My experience w/ Cool Carbon ST pads + RBF 600 fluid + F30 backing pads @ thunderhill
Context:
First time at Thunderhill in my lightly modded 135i (SplitSecond Turbo Tuner chip, afe Dual Intake, RPI exhaust, HR springs, Koni Yellow Coilovers).
This was my first track day ever. Friend was running in a stock BRZ. Both of us are competitive drivers who are speed enthusiasts and are hooked to the track now.
Brake system setup:
Cool Carbon ST Pads
F30 Backing plate retrofit
Motul RBF 600 (Racing Brake Fluid)
Over Saturday and Sunday, we both had instructors to get the right line and right speeds. We pushed ourselves to the limit. We did 9 x 25 minute sessions over these two days.
Fade: None over the 25 minute sessions. I was braking extremely hard. I was running with PCA and all the instructors agreed that my brakes were absolutely fantastic and I was definitely using the crap out of them. Fluid never boiled. The BRZ experienced fade doing hard corners. I was smoking my pads doing my 120mph->35mph braking on turn 14.
Wear: Have tons of meat left. TONS. Doesn't look like the track destroyed my pads at all, but I'm sure they did do a number on them. I'm very very happy with how much is left. The BRZ was a brand new car with about 5000 miles on it (no hard driving). After the track, the pads were completely GONE. We actually rushed to the local O'reilly's and had to get him pads right before sunset (and install them in a parking lot) before making our 180 mile journey home.
Grip: Great. Just great. My tires were the fault here.
Noise: none:
Dust: Much less than OEM. Soooo little. I cannot complain.
All in all, if you run these three things in your 135i, you will have a great time. I never felt my brakes fade once. I had full confidence in them every single turn. Instructors who were all driving Porsches said my car was absolutely fantastic to drive and had phenomenal power and brakes - far more than I can use effectively.
I had a great time..I only hope my pistons aren't cracked! :O
1997 328i / sold
1999 M3 / sold
2009 135i / current
      03-30-2015, 08:36 AM   #2
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
Wow! Complete different experience than I had. You were probably out on a track with long stretches to allow for better cooling, and tires that were not that sticky ( inferior to the Extreme Performance category).
See the feedback in this thread ... http://www.1addicts.com/forums/showt...3#post16457263
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      03-30-2015, 12:31 PM   #3
psamtik
Involuntarily BMW
31
Drives: 09 E82 135i
I'm not in a JB4 tuned car - and thunderhill does have a lot of straights that allow cooling for sure.
I was just chewing through my stock run-flats.
Seems the opinion from many folks on this forum isn't that positive - maybe CC did something to the pads...I had no problems at all!
1997 328i / sold
1999 M3 / sold
2009 135i / current
      04-01-2015, 03:38 PM   #4
02rsxpilot
02rsxpilot's Avatar
Drives: 2012 BMW 135i
2012 BMW 135i  [10.00]
2013 Mini Cooper S  [0.00]
2002 Acura RSX  [0.00]
Thunderhill is a fairly brake-friendly track. If you ever head to Laguna Seca, I'd recommend stepping up compounds in the front. The T2-T3 section pushes the upper limits of a pad's temperature tolerances.
Welcome to the fray though!
2012 BMW 135i DCT - M3 Front Control Arms, Whiteline RSFB, Dinan camber plates.
