03-24-2015, 06:57 PM | #1 |
31
Rep 192
Brake pad sensor
I disconnected my brake pad sensors awhile ago. While disconnecting them I broke one of the sensors. Recently I installed bbk. While doing the install I decided to get a new sensor to replace the sensor I broke. After I installed my bbk I plugged the new sensor and zip tied it to the side. I was expecting the new sensor to make the brake pad light go away but it hasn't gone away.
How do I get rid of the brake sensor light on my dash now with my bbk on? |
03-24-2015, 07:06 PM | #3 | |
31
Rep 192
03-24-2015, 07:10 PM | #4 |
3282
Rep 6,726
Originally Posted by edwinm3 View Post
What you guys need to do in this case is, disconnect the sensor and jump the two wires on the harness connector that the sensor connects to. While having this jumped, reset your light and when done, reconnect the sensor. Done it a million times and works every time unless sensor is bad. http://www.m3post.com/forums/showthr...=478138&page=2 |
03-24-2015, 07:12 PM | #5 | |
31
Rep 192
Thanks. |
03-29-2015, 08:16 PM | #7 |
84
Rep 147
Finally got down to fixing the brake light. I needed 2 front sensors as they were cooked. Left the rear since it looked perfect and I didn't feel like removing the wheel well lining. Zip tied all to the struts. Started the car. Reset from the BC stalk. And perfecto! No more warnings for the first time in months!
Thanks to all for the tips |
03-29-2015, 08:53 PM | #8 |
174
Rep 1,246
Drives: E92 M3
Also, if you don't care about the wear sensors, you can cut the wire, splice the wires together and essentially complete the circuit again. I check my own brakes regularly, so I don't really care about the brake sensors.
04-18-2015, 12:27 PM | #9 | |
31
Rep 192
04-18-2015, 01:56 PM | #10 |
3282
Rep 6,726
There are 3 sensors. Need to try the other ones as well. Also some people are having luck disconnecting and reconnecting the battery. Battery trick won't work if you still have sensor issue on other wheels
