      01-29-2015, 05:09 PM   #1
alibaba222
Drives: BMW M4
wtb: 3rd brake light
so my 3rd brake light just broke and i need a new one, let me know if you have one or if you know where to get one at a good price lmk.
thanks
      01-29-2015, 06:32 PM   #2
cbl117
cbl117's Avatar
Drives: 2013 e92 335i
Get in line lol. Search for my thread. There is a link to getbmwparts. Its 70 bucks.
      01-30-2015, 08:18 PM   #3
TUN3D
TUN3D's Avatar
193
Drives: none
alibaba222 > I recently got mine on ebay NEW for $25 > OEM. I see some on there now for like $40-$50.
Keep in mind though (not sure what year your car is), that at certain point they changed the housing on those 3rd brake lights. My car is a '09.
Prior to picking one up on e-bay, I ordered it straight from BMW. I'm 100% sure I got the right part number (trust me on this). Anyways, when I compared it to the one I removed, it was different. Long-story-short, the newer lights don't pop right in. When you remove the broken light, there is a small tab on the chassis/trunk that needs to be filed down. You'll also need to sand the light housing a bit (small section in the middle), in order for it to fit. The problem will become apparent once you try to put the new light in.
Not saying this is going to be your case, but if you have trouble -- don't waste time thinking you got the wrong light. I spent two weeks figuring this out. LMAO!
Good luck man.
      01-30-2015, 08:39 PM   #4
cbl117
cbl117's Avatar
Good luck man.
Tuned are you saying the eBay light will be plug and play? Or will the same filing and sanding need to be done?
CURRENT: 2013 TSM 335i 6AT | Stock!!...for now |
SOLD: 2010 CR 135i 6MT | 351 WHP 387 WTQ | Dinan Stage 2 | Dinan Intercooler | BMS DCI | Berk Street Axle Back | N55 Midpipe | BMWP Y-Pipe | Bilstein HD Dampers | BMWP Springs | Whiteline RSFB Inserts | 225/255 RE71R | CDV Delete | CF Diffuser |
      01-31-2015, 08:15 AM   #5
TUN3D
TUN3D's Avatar
193
Drives: none
cbl117 > Even the ebay lights you have to modify. Like I mentioned (at some point), they changed the designed of the light housing. Due to that, the new lights that are available (both at the dealer or ebay) -- need a little adjusting to go in.
The issue is literally at the center of the light. Here I found a good DIY, he covers it all
DIY > Dackelone
http://www.1addicts.com/forums/showthread.php?t=845005
      02-27-2015, 01:59 PM   #6
cbl117
cbl117's Avatar
DIY > Dackelone
Excellent info. Thanks tun3d.
