New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      01-28-2015, 01:14 PM   #1
Bob20124
Retired and Enjoying it
Bob20124's Avatar
Drives: 2011 Z4 35i Alpine White 6MT
LSD
Finally installed M Factory LSD (pumpkin) bought during "Black Friday" sale. 3Hrs start to finish by a BMW Mechanic with lift and proper tools (and my help). Amazing what you have to drop to swap the diff. back belly pan, diff shield, triangular rear brace, Exhaust, heat shields, rear sub-frame, rear sway bar, and center driveline support. Then you can disconnect splined driveline (special spanner wrench required) and rear wheel 1/2 shafts. Pull mounting bolts and drop pumpkin down on a tranny jack. Install of new unit was straight forward reversing steps above. Dropping and reinstalling the pumpkin and exhaust is a 2 man job.
This is not something to attempt on jack stands.
Really didn't have a chance to fully evaluate on trip home. Definite improvement though no noise, clunks, or vibration. I will evaluate this spring. The car is put away for the rest of the winter
2011 35i BMS High & Low side OCC, Custom tune, CDV delete, Eldor coils, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, NGK plugs, Racing Dynamics strut brace, Stubby, Windrestrictor
      01-28-2015, 01:31 PM   #2
Drew@Sonic MS
Drew@Sonic MS's Avatar
334
Drives: F80 M3
It's possible to do it with just slightly dropping the exhaust and leaving everything else there. Sway bar just needs to be disconnected and pushed away.
Definitely a huge improvement for our cars though! Curious how the M-Factory performs compared to usual brands.
      02-02-2015, 04:45 AM   #3
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
Very nice! Congratz! Time to waste some rubber then!
      02-02-2015, 03:04 PM   #4
Vintage
Vintage's Avatar
Drives: BMW G80 (MT), 718 Spyder
super cool - I am jealous and I have always wanted this for our little e89
      02-03-2015, 03:50 PM   #5
jts1981
jts1981's Avatar
213
Drives: n54
+1
Think it would be a noticeable improvement.
      02-28-2015, 01:16 AM   #6
goktuk
9
Drives: Z4 3.5i DCT
Lsd for e89 3.5i DCT ??? Ä°s it possible??? Ä° know some brands can do it but they need oem diff and they mix both diff with oem diff ring.
Because e89 Dct has Do you have a welded differential.
Quaife BMW LSD Conversion - install a Quaife LSD into your original final drive housing. If you are abroad, you can send your final drive here for conversion.
      03-01-2015, 11:50 PM   #7
talhagursoy
talhagursoy's Avatar
Drives: Bmw Z4 sDrive35i
where did you install it, and how much the laber cost ?
      03-02-2015, 01:17 AM   #8
Bob20124
Bob20124's Avatar
PM sent.
      03-02-2015, 01:41 AM   #9
pavproch
9
Drives: Z4 3.0i & 330ixT
+1 for Quaife
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      03-03-2015, 06:39 PM   #10
italy3541
italy3541's Avatar
58
Drives: Alfa Romeo 4C
Im interested in the cost and whats needed for this.
      03-04-2015, 02:10 AM   #11
pavproch
9
@italy: Are you referring to the quaife LSD or M-style ?
If the former: the pricetag shows something like 1500 USD for the HW + installation costs (exctracting the diff out, dismantling it, quaife fitting-in - some precise measurement will have to be done, oil refill and diff reinstall).
I would say something like grade 5 on a scale 1 thru 10.
Hope it helps.
      03-04-2015, 04:32 AM   #12
italy3541
italy3541's Avatar
58
I am interested in any of the options. I did a little research yesterday, and it seems there are a few options. Quaife, wavetrac, or M style. I am trying to figure out what one is the best option for me. I would prefer some type of strait bolt in, but I am not sure which one or if that is even possible. I will have to do more research.
      03-04-2015, 05:37 AM   #13
Bob20124
Bob20124's Avatar
I went with M factory. The E89 does have a welded ring. They have the capability to rebuild the pumpkin and put a new ring on their helical style LSD units. The only other company I found in the states will machine off the existing ring and reuse it is VAC in PA. Email Stephen. He is a pleasure to deal with. Tell him we talked. syeh@teammfactory.com I am extremely pleased.
      03-04-2015, 06:53 AM   #14
pavproch
9
Only 35i(s) have a welded one, so luckily I had a much wider choice with my 30i (bolted).
BTW, some tech-comments:
Quaife = "worm" type LSD while M-style one = "lamelle" (Drexler) type
worm = slip ratio cannot be "tuned" ("off" or "100% on", nothing in between)
lamelle = they (at Drexler) can set the threshold to 25, 50 or 75%...
worm means no running maintenence apart form occasional oil change (per 30k miles)
lamelle = regular maintenance needed (oil per 8k miles, lamelles to be changer upon driving style)
zpost
