01-27-2015, 02:59 PM | #1 |
2312
Rep 12,654
Teaser: Stoptech BBK Test fit on F82 M4
01-27-2015, 03:03 PM | #2 |
1397
Rep 3,152
Sweet... are they really better then the OEM Brembos?
01-27-2015, 03:21 PM | #3 |
2312
Rep 12,654
01-27-2015, 04:03 PM | #4 |
2042
Rep 25,989
Nice!
VMR|Wheels | 714.442.7916 |
01-30-2015, 04:42 PM | #11 |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
01-30-2015, 04:47 PM | #12 | |
214
Rep 981
My issues stems from the materials they used. On my calipers the pads slid on something called an abutment plate. Was made of bare aluminum. So this bare aluminum obviously corroded and when they did they bit onto the brake pad. This caused me to cook that rotor, the brake pads were destroyed from the heat I guess, and the abutment plates were obviously destroyed from the corrosion. So I get in touch with stoptech who sent me to a local distributor since I bought them 2nd hand. The distributor told me that it's recommended to either wash off the calipers or not run them in salty (winter) condition as this can happen. Ended up costing me nearly $1000 with parts/ labor/ and a fresh powder coat. Here's some pics that show the abutment plates Last edited by apexit; 01-30-2015 at 04:52 PM.. Reason: picss added |
grayracing0.00 |
01-30-2015, 04:50 PM | #13 | |
1518
Rep 4,744
01-30-2015, 05:49 PM | #16 |
5414
Rep 10,825
Must agree, was using them on my previous LB M3 and loved them.
01-31-2015, 06:04 PM | #17 |
382
Rep 2,067
The rotors look cheaper than stock, are they two piece? They also look smaller in height and width
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB |
02-01-2015, 04:31 PM | #20 |
721
Rep 2,342
The upgrade will come from the additional pistons, stiffer caliper, steel lines, and the large selection/availability of pads. Plus swapping the pads is quick assuming they don't fart on the abutment plate manufacturing like the set I had. Apexit - I also had issues with my abutment plates, but the corrosion is definitely a new one. Thanks, I'll keep an eye on them.
Stock brakes are already 380mm, so ST's 380mm rotors are not going to be any bigger, but maybe thicker. Pretty much every friction ring is ST's catalog is 380mm for front axle applications. It's not unexpected though. Only people I see going for this would be a track person. Any bigger and they could not fit 18" wheels which are preferred. Solid/slotted rotors are more boring to look at but they are super durable. |
02-02-2015, 01:01 PM | #21 |
2312
Rep 12,654
