01-24-2015, 07:29 PM | #1 |
32
Rep 178
How did you mount your JB4/piggyback?
So I'm working on the install of the BMS Stage 1, which is basically JB4 instructions. The instructions call for tie wrapping to the frame, but I'm concerned there could be some water damage, or maybe eventually vibrate this little box to pieces. I was thinking about either making a bracket with some rubber surrounds, or at least wrapping it in a balloon if I'm going to tie wrap it.
Thoughts? On a more shitty note, I was removing the two T-25 torx bolts to move the inter-cooler reservoir out of the way and one of the bolts dropped into what sounded like purgatory. I tried fishing it with a magnet but couldn't find it. Where can I find a replacement bolt, anyone by chance have a part number? Thanks |
01-24-2015, 08:37 PM | #2 | |
439
Rep 1,732
01-24-2015, 08:44 PM | #3 |
32
Rep 178
Yea so what I did was I put a pair of vice grips on the hose that goes from the intercooler to the tank. I opened the cap on the tank to bleed the pressure, then I just used pliers on the hose clamp and it as well as the hose slid right off. I didn't get much drainage but I put a little rag under neath the nipple where the hose came off. Once you do that, the two bolts are t-25 torx. You can basically lift the reservoir and move it out of the way very easy.
Hopefully that helps, ask away |
01-24-2015, 09:12 PM | #4 |
Joint Chiefs of Staff
4918
Rep 115,980
Mount it under the strut brace using a zip tie as shown in the guide. This is the best location to keep it protected and safe. There is no need to do anything "custom" with it.
Mike |
01-24-2015, 09:32 PM | #5 | |
439
Rep 1,732
01-24-2015, 09:48 PM | #7 |
439
Rep 1,732
01-24-2015, 11:40 PM | #9 | |
70
Rep 261
01-25-2015, 09:53 AM | #10 | |
32
Rep 178
01-25-2015, 09:58 AM | #11 | ||
70
Rep 261
01-25-2015, 10:16 AM | #12 |
32
Rep 178
Ordered this:
https://www.fcpeuro.com/products/bmw...22-11617533331 Should be close, will have a review today I hope. |
