01-24-2015, 05:47 PM | #1 |
244
Rep 553
JB4 Pushing Boost Limits - Heads Up To All
Just wanted to share a quick story. I don't know all of the technical details and I'm not the best story teller on these boards so bare with me. Hope this isn't a re post but I searched the forums and couldn't find anything...
I've been running the JB4 tune on Map2 for about 3-4 months now. I've had numerous drive train malfunctions. No big deal really - engine always checked out fine and ran perfect after a restart. That was until last week... One evening I was running car extra hard on the freeway(car was warmed up - this event didn't happen until a good 30+ minutes of driving). Shifting between 3rd and 4th gear I heard a tremendously loud POP, almost like a mini-explosion, followed by the familiar drive train malfunction. I pulled over, restarted the car and proceeded on. The only problem was that I has almost no power - as if I were driving a 320i - and under acceleration when the turbos would normally spool I could only hear a loud whistling from under the hood. I limped the car back to my local shop the next morning to have a look. Turns out one of the plastic pipings that leads from the turbos to the engine has simply exploded EVERYWHERE leaving plastic shards and metals links all over the engine bay. The explosion was so intense that part of the engine cover had even been broken to pieces. See example photo below, although not my actual engine, the area in red(yes, the penis shape) was entirely gone - vanished. Luckily just a few replacement parts were needed and a day of service. Most likely something like this won't be covered under warranty so keep this in mind when deciding on a piggy-back. I still wouldn't drive this car without it!
2015 F82 M4 :: BSM/Black :: ESS Flash Tune :: 19" HRE FF01 Satin Black :: H&R Sport Spring & 12mm/15mm Spacers :: Eisenmann Sport Exhaust Gloss Black / Down Pipes :: SOLD
2016 F85 X5M :: Donnington Grey/Mugello Red :: SOLD 2016 F85 X5M :: Mineral White/Mugello Red :: Stock...for now |
01-24-2015, 06:05 PM | #3 |
506
Rep 1,385
What you experienced is why Most boosted cars that are upgraded have metal charge piping. Plastic can only hold so much before it gives. Normally what goes first or gives out are the couplers that attach the charge piping to the intake.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
01-24-2015, 06:06 PM | #4 |
10161
Rep 8,626
Lol... you think this has to do with the fact that this is a piggypack as opposed to simply elevated boost?
The knowledge on this forum is amazing.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
01-24-2015, 06:09 PM | #5 |
329
Rep 984
Interesting, I've run up to 31psi and haven't had such an issue, luck of the draw I suppose.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
01-24-2015, 06:20 PM | #6 |
506
Rep 1,385
What are you running to monitor boost to verify you are actually running that much boost on those tiny turbos? I'd actually be quite worried about them at that pressure given there compressor size. running a turbo out of it;s offiecency rang equals nothing but heat and that leads to detonation and failing ringlands.
01-24-2015, 06:43 PM | #8 | |
Sergeant
808
Rep 2,510
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels | |
01-24-2015, 07:19 PM | #9 |
33
Rep 174
One guy has a issue compared to the hundreds running jb4 and automatically we blame the jb4? Interesting all i can say is ive been running the jb4 for 4500miles on e85 and 5000miles on meth and e85 with no problems.
01-24-2015, 07:32 PM | #11 |
244
Rep 553
I think the tone and attitude I took in my OP was extremely fair. I am in now way mad, upset or claiming any type of foul. Just outlining an issue that happened to me in the Engine section of the board.
I didn't say anywhere that it would happen to everyone - I'm happy that after so many miles it hasn't happened to you, flewbyu335. Over the years many issues will come up with these cars, tunes, aftermarket parts, etc. that will happen to some and not others. Simply here sharing an experience. I'm not trying to stage a witch hunt - I even closed my OP by saying I wouldn't want to drive the M4 without the JB4. This is a forum - without sharing experiences and information there would be nothing here!
01-24-2015, 07:33 PM | #12 | |
244
Rep 553
As for drivetrain mal: http://f80.bimmerpost.com/forums/sho...6#post17203666
01-24-2015, 07:39 PM | #13 | |
253
Rep 551
Charge pipes have a history of cracking on N55's and N20's, so this wasn't completely unexpected. |
01-24-2015, 07:51 PM | #14 |
296
Rep 1,515
Drives: Ever changing fleet
Charge pipes on most turbocharged BMWs can be suspect when upping the boost. It is a common problem in the N54/N55 world to have the charge pipe break...this is regardless of the type of device used to raise boost levels.
In this case, this is the first I've heard of it and you are running more "moderate" boost levels. You may have had a defective charge pipe. I guess we'll wait and see.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
01-24-2015, 08:16 PM | #15 |
Olimpiakos
91
Rep 1,426
OP, I had the same thing happen to me when I only had 500 miles on the car. It was the pipe closest to the front of the car though. It was shattered. I did NOT have the jb4 in. My car was still stock. I've had the jb4 in since about 1000 miles and no issues.
My dealer replaced the 2 pipes and called BMWNA to try and get a tsb put out on the pipes because I wasn't the first person to have that issue with a brand new M3. And I'm pretty sure each pipe is between 80-100 bucks each. So not real expensive at all. |
01-24-2015, 08:26 PM | #16 |
Croatian
884
Rep 3,613
Drives: PORSCHE
This happened on early test cars where the charge pipes "popped" off during track sessions.
Maybe we need an after market solution since we're running high boost than stock.
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
01-24-2015, 09:10 PM | #17 |
Joint Chiefs of Staff
4918
Rep 115,980
This is the first charge pipe failure I've heard about on the S55 but if its a weak point it won't be the last. Sooner or later Evolution Racewerks and other companies will offer stronger pipes.
Mike |
01-25-2015, 08:11 AM | #19 | |
Mr. Fluffy
35
Rep 274
01-25-2015, 08:21 AM | #20 |
1904
Rep 5,678
The bigger issue, IMO, is that if your BMW shop now knows you had the JB4, then they would have flagged the car and there is likely no warranty at all on any future engine issues (or, at least, without major fighting). Hopefully the shop you took it to wasn't a BMW dealer and/or you didn't alert them to the mod .
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
01-25-2015, 08:40 AM | #22 |
89
Rep 399
The reason why your car goes into Limp Mode is bc you got Limp dick drawn on your engine bay.
Delivered 11/28
YMB F80 - Excutive, DCT, and SO int. Current ///AMG 2009 P30 Calcite White C63 - V4 Eurocharged ******* 2012 Mini Countryman S JCW |
