01-18-2015, 10:50 AM | #1 |
876
Rep 1,319
Liquid to air intercooler maintenance ?
Hello Chaps,
Collected my M4 over the weekend, and have been having a good nosey around it. The only question i have atm is, do you have to top up the little black plastic tank, that holds the fluid for the top mounted intercooler/Chargecooler at the very back of the engine bay ?. There is nothing at all in the owners manual about it, ive even scrolled through the owners handbook pages in the I Drive, but there is no mention at all, so maybe this is something that will never need any fluid top ups ?, thankyou, regards, SIMON. |
02-25-2015, 04:57 PM | #4 |
65
Rep 503
Same question but phrased differently, I just lost some fluid installing the Stage 1 BMS, what do I add? Distilled water? Antifreeze? Mix of both? Thanks in advance
P.S. The added 50/50 HP/TQ felt amazing |
02-26-2015, 08:34 PM | #7 | |
1383
Rep 3,834
Daily: G12 750 MSPORT Weekend Car: E90 M3
07-28-2015, 01:37 AM | #9 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Water actually has a higher thermal conductivity than Glycol, which is what most Antifreeze are made of. Straight water with an additive like Redline's Water Wetter will keep your engine cooler than a 50/50 mix all day long, the additive will also give you the lubrication for the water pump and any seals in the system. On the S55 that could also mean lower IAT's. For areas with below freezing temps, you are stuck with the 50/50 mix.
Alpine_F82215.50 |
07-28-2015, 06:11 AM | #10 | |
21117
Rep 20,741
Drives: 2021 911 turbo
Also note that the intercooler system will likely never get close to boiling temps; if it does, it means it will have seriously heat soaked
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 07-28-2015 at 09:02 PM.. |
07-28-2015, 08:07 AM | #11 |
Joint Chiefs of Staff
4918
Rep 115,980
07-28-2015, 11:46 AM | #12 |
29
Rep 48
Wondering if water wetter works?
https://instagram.com/p/5nyT6CAskJ/2015 ymb f80m3=acm built dme tuned 660whp/676wtq @26psi e30 mix pure stage 2 turbos, Dodson sportsman, bms intakes, stock ic and charge pipes, gintini dp's stock exhaust gutted, 265/305 r888s
Ex cars= 10,gtr,10m6,14raptor,10ml63amg, 08sl55,06ctsv,96supra, 95supra, 01 type R, plus loads of daily drivers |
07-28-2015, 11:54 AM | #13 | |
3847
Rep 54,376
Drives: F80 M3
There is absolutely an advantage switching to distilled water with an additive(Redline or Motul). |
07-28-2015, 12:49 PM | #14 |
2712
Rep 2,371
Any of the water wetter type stuff will help. They all work by reducing surface tension (kind of like soap) on the water, allowing it to transfer more heat, also reducing instances of 'micro-boiling' (small spots where air bubbles form) Don't want to overdose on it, though, you still need the base water to actually do the heat transfer.
2015 Black Sapphire Metallic 6MT M4
07-28-2015, 06:52 PM | #15 |
1030
Rep 1,190
But . . . We've seen that even modded cars have absolutely no issue with cooling or heat soak. Why mess with chintzy aftermarket stuff like water wetter when the OEM 50/50 mix works fine and is what BMW intended? All the seals and materials in the cooling system are designed to work with BMW coolant.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
07-28-2015, 07:42 PM | #16 | |
3847
Rep 54,376
Drives: F80 M3
07-28-2015, 11:31 PM | #17 | ||
1030
Rep 1,190
07-29-2015, 12:18 PM | #19 |
3847
Rep 54,376
Drives: F80 M3
11-01-2017, 08:54 PM | #20 |
2896
Rep 3,726
11-04-2017, 11:54 AM | #21 |
3847
Rep 54,376
Drives: F80 M3
hellokitty2895.50 |
