01-16-2015, 12:05 AM | #1 |
657
Rep 1,749
linear power to redline
I for one am pleasently surprised with top end pull of this car.coming from an e92 m3, I saw the flat power curve up top and feared it would feel dead. However it feels like it pulls hard to 7500 rpm and frankly feels very similar to e92 only way more power. I am surprised frankly as I though constant power and flat power would feel subjectively like a drop in power but it doesn't so I'm not seeing how some reviews don't find it exciting to redline the car!
01-16-2015, 12:44 AM | #2 | |
307
Rep 971
01-16-2015, 12:56 AM | #3 |
657
Rep 1,749
Lurch forward is dct shifting with no power interuption. Really doesn't run out of breath until 7600 which is redl8ne. 7500 is full power. 5500 to 7500 is essentially 420whp . Amazing force to me
01-16-2015, 05:39 AM | #4 |
21117
Rep 20,741
Drives: 2021 911 turbo
What is causing the "lurch" with DCT is the fact that the DCT does a "power shift", where the transmission recuperates the energy of the engine inertia from the drop in RPM and converts it in forward momentum of the car. The higher the RPM drop, the stronger the lurch.
Try a WOT high RPM shift in S1, there is no power interruption during the shift but also no lurch. According to BMW, power plateau ends at 7300rpm, not 7500rpm. Last edited by CanAutM3; 01-16-2015 at 10:09 AM.. |
01-16-2015, 06:48 AM | #5 | |
592
Rep 5,396
The e92 also has a torque drop near redline which has the power curve flatten out a little too. Imo that was almost more noticeable because the car had less power to begin with. I think the engine feels great, and I like the linear torque and power build at lower and mid rpm as well, as compared to the bigger early hit of power from the n54. |
01-16-2015, 12:44 PM | #8 |
2681
Rep 3,406
What you guys are feeling is merely the pull of a faster car compared to an E9x M3.
There is a significant, undeniable difference in powerband characteristics and feel between most performance NA engines which make peak HP at or near redline and turbocharged engines. The S55 does not make additional power after 5500-6000 RPM which is the result of torque falling at a rate fast enough to keep HP flat to redline. This is exacerbated when modded where torque takes a nose-dive up top and peak power is made around 6000 RPM then is falling towards redline. Just because power is no longer longer climbing (or falling) doesn't mean the car isn't accelerating. The car has something called gears. It has more to do with the rate of change in acceleration. With a linear powerband, the rate at which speed is increasing remains more constant than if power was flat/falling and the rate of acceleration is slowing. This results in a sensation of being pushed back in the seat harder as revs climb. |
01-16-2015, 01:00 PM | #9 | |
21117
Rep 20,741
There were so many posts where folks speculated that the S55 woud fall flat on its face past 5500rpm, that the engine would need to be short shifted at 6000rpm etc... I think the point being made here is that he car keeps pulling strongly at high RPM. In fact to extract maximum performance out of the F8X, redline or near redline (7300rpm) shifts are needed. To be able to achieve this, you would need a torque curve that keeps increasing in the power band (i.e. a torque peak achieve at/near redline). On the vast majority of cars (not to say all) the acceleration rate decrease as the revs increase in the power band, hence you are not getting pushed harder in your seat . |
01-16-2015, 01:35 PM | #10 | ||
2681
Rep 3,406
Haven't timed acceleration or had the car at a drag strip, but based on the powerband, shifting at redline for max performance is likely only if completely stock. When modded, optimum shift point will certainly be much lower. Quote:
With a completely flat torque-curve, HP is upward-sloping and more power is made with each increasing revolution. Mated to gears which multiply torque, yes...the car's rate of acceleration remains close to constant in any given gear until air resistance becomes a greater factor. Are you just arguing for the sake of it? |
01-16-2015, 02:02 PM | #11 | |||
21117
Rep 20,741
I agree with you, tuned can be different depending on what the tune does to the torque/power curve. But the OP is discussing stock car, not tuned. Quote:
For instance, on the S65, when shifting at redline for maximum acceleration, the RPM always stays well above the 3900RPM torque peak and the torque drops from that point all the way to redline, hence reduced acceleration. Further, even if the torque curve is perfectly flat, aero and rolling drag increase exponentially with speed and, as a result, acceleration will therefore decrease with increasing rpm. My point is that even on NA cars, there is an acceleration drop off. It is not a FI car thing only; albeit it is usualy more pronounced with FI. Isn't that the whole point of the forum Last edited by CanAutM3; 01-16-2015 at 02:45 PM.. |
01-16-2015, 06:37 PM | #12 |
1099
Rep 2,286
Having also come from an E9x M3 - I have to say that subjectively, the acceleration on the F8x from 6,000 to 7,600 rpm feels just as ferrocious as my E9x did up to redline (no more, and no less in that rpm range).
I am well aware of how different the hp/torque curves look for the S65 vs. the S55 engines. That being said, and given my experience - I also don't understand people taking the position that the S55 does not accelerate very hard all the way to redline - it clearly does!!! |
01-16-2015, 07:06 PM | #13 |
2681
Rep 3,406
01-16-2015, 07:39 PM | #14 | |
1099
Rep 2,286
You can sit there and point to graphs and objective data all day long (which nobody on here is disputing). All we are saying is that in no way is the S55 disappointing up to redline. |
