01-07-2015, 06:28 PM | #1 |
33
Rep 194
101 Octane
My M4's been limited by 91 octane, so I decided to fill half my tank with some expensive ass 101 octane fuel just to see if there was a difference. I drove around for a bit, let the fuel "simmer" in the engine, warmed up my tires, then pushed it pretty hard.
At first, I thought "damn…this is awesome! It makes my car so much faster". Then after a couple other runs of accelerating hard - both from a crawl and from higher speeds - I though that the difference wasn't that great. In the end, I felt like the fuel made the car perform better, but certainly not something I would buy on a regular basis. Anyone know how much, if any, of a difference there is with higher octane fuel? For all I know this could be all placebo effect!! |
01-07-2015, 06:55 PM | #2 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
Unless you have an aftermarket tune designed to take care of it, I seriously doubt there's much of a real effect there. BMW doesn't design their engine parameters for 101 octane.
On the other hand, depending on the mix, you are probably pushing your effective octane into the mid to high 90s. That might make a little difference. |
01-08-2015, 11:16 AM | #4 |
43
Rep 177
BMW did design the car for 93. Putting in 91 will reduce performance. I have ESS and I was told that their tune can take advantage of the octane up to 96. I mix my tank just to get to around 96. I can feel the difference easily.
2019 Range Rover Supercharged
2015 Ferrari F12 |
01-08-2015, 12:40 PM | #5 |
47
Rep 287
Drives: '15 GT-R, '02 996TT
If you've been running 91, then you'll definitely notice a difference when switching to higher octane since you no longer have reduced performance. However, to get max benefit of higher octane, there needs to be a custom tune for it. But on the dyno, doing a baseline on 91, then one on a higher octane mix will yield a delta.
01-08-2015, 01:13 PM | #6 |
214
Rep 981
all the higher octane will do is let the engine run better/ smoother. Without tuning there wont be much of a difference and even then you'll want a tune to maximize the higher octane.
02-15-2015, 06:14 PM | #9 |
Philosophiae Doctor
208
Rep 873
02-15-2015, 06:52 PM | #10 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
All the octane rating is the resistance to detonation. Higher octane might trick the computer to alter timing but without a tune, you won't see any real difference. The sock tune is no where near tuned for 100+ octane.
02-15-2015, 07:04 PM | #12 |
657
Rep 1,749
Yes you actually will. 91 and any heat will cause timing to be pulled quite quickly. So it will allow you to make full power. In e92, you couldn't hit full timing target with 93 in summer temps. It too needed 95
02-15-2015, 07:11 PM | #13 |
2095
Rep 43,350
Anything above 93 octane will not show any gains on the stock tune. Race gas/high octane fuel will only provide you with knock resistance. There isn't something magical in the fuel, it's simply knock resistance
The DME doesn't read the higher octane gas and up timing. That'd be too easy. If you're using higher octane fuel as a knock suppressant like your extreme heat example then you'll make the same power you're supposed to make, you won't increase HP on the stock tune. |
02-15-2015, 07:14 PM | #14 |
657
Rep 1,749
It actually does. Since e46 M3 generation. It will advance timing progressively atleast on e46 and e92. It doesn't measure octane but pushes timing until essentially knock detectected. Many have logged this on past m cars
02-15-2015, 07:23 PM | #15 |
21117
Rep 20,741
Drives: 2021 911 turbo
A good example of this is Dinan who was able to log a 11hp gain on an E46 M3 by simply going from 91 to 93 octane fuel:
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
