01-02-2015, 10:35 PM | #1 |
123
Rep 241
Jerky take off pls help
Hi everyone
My car has only 3000km on the clock. 2 days ago I drove a 600km trip to the coast. When I got to my destination I notice that if I take off from standstill a little aggressively my car jerks a little and then she goes. If I take off slow everything seems nice and smooth. If I am at a stop and press my accelarator half or three quarter down my car goes then gives a jerk and carry on. I tried in efficient and sport same result. Does any member know what this might be. It makes me look like a useless driver. Thanks in advance for any input. |
01-02-2015, 10:51 PM | #3 |
123
Rep 241
Yes u right
The moment u put it in second and floor it it's fine. My worry is I don't remember it being there before. Not sure if I never tramped it before because I was running the car in nor did u try the launch control yet. Either way I'm sure this can't be normal. |
01-02-2015, 11:26 PM | #4 |
1882
Rep 3,341
What car did u have before the m? R u in the most aggressive shift setting? Have u tried in the least aggressive and efficient for the the throttle mode?
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
01-03-2015, 02:30 AM | #5 |
3169
Rep 2,135
This also happened in my e92.
01-03-2015, 07:13 AM | #6 |
410
Rep 1,025
What throttle map are you in? Efficient, sport, or sport plus? Sport plus is the most sensitive and the most difficult to be smooth in. I've switched back to sport and sometimes prefer efficient because it's smoother for throttle modulation.
01-03-2015, 12:36 PM | #7 |
123
Rep 241
I use only efficient and sport.
Never tried sport plus. If it's normal I can live with it. It's just that I never felt it for the first 2500 km. I know I was running the car in so I never really gave it the beans. |
01-03-2015, 05:19 PM | #8 |
INSTAGRAM: @yaasplease
166
Rep 1,023
It's called the "bunny hop". There is nothing wrong with the car. It's your right foot that's the problem. With a sensitive throttle, when you press the throttle, the car's front end raises slightly, causing you to press a little harder than you intended to. So your body retracts your foot a little, causing the car to slow down, and the front end drops. Then you subconsciously press a little harder and the cycle continues until the sensitivity is eliminated, which can be done by switching to second gear, or slam on the gas pedal. To prevent it don't go beyond "sport" for throttle response.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
