12-29-2014, 12:13 AM | #1 |
202
Rep 283
Installed F80 M3 Akrapovic Downpipes (with video)
After a 3 month delay, I finally received my Akrapovic downpipes.
Dropped the car for the 10k service plus some recalls and will get it back with the downpipes installed. Here are some box pics. I also took the car to the local drag strip and managed a 12.1 at 191.06km, so will see howit improves. Last edited by uae247; 12-31-2014 at 03:16 PM.. |
12-29-2014, 06:52 AM | #3 |
10817
Rep 27,600
sweet, your going to love it I'm sure. Def shoot some vid so we can all be jealous!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
12-29-2014, 10:17 AM | #6 |
202
Rep 283
I will do some cold start
running and acceleration videos Plus will see how much it improves using the Vbox. As for the delete-R, there is still a delay till Jan or Feb. |
12-29-2014, 12:52 PM | #8 | |
114
Rep 424
so I guess no one has the delete-r yet.
Currently:
2022 M4 Comp xDrive 2022 M5 Comp Past: 2019 M5 Comp 2015 M4 |
12-29-2014, 03:42 PM | #9 |
202
Rep 283
12-29-2014, 03:43 PM | #10 |
202
Rep 283
12-29-2014, 07:18 PM | #12 | |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
They look sick. Good luck! Can you enlighten us on what recalls they're performing?
LIVE FAST..DRIVE FASTER!! |
12-29-2014, 11:32 PM | #13 |
70
Rep 287
They look great with the Inconel heat insulation. I'd be interested in comparison with a ER or other non shielded DP in regards to intake, oil and coolant temps during track use.
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue |
12-29-2014, 11:53 PM | #14 |
70
Rep 287
Also instead of delete R (which is an OBDII plug right?) you could use a mini-cat/extender.
Supersprint make them as well: http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
12-30-2014, 12:45 AM | #15 |
980
Rep 4,001
Pipes are pipes, doubt they'll be a lot of difference. These are very well manufactured of course, Akra FTW
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
12-30-2014, 01:21 AM | #16 | |
202
Rep 283
1) Charge pipe hose clamp...they add an additional hose clamp to the intake coming from the intercooler to avoid pipes blowing off from boost 2) Door and window frame squeak....same as what I complained about when I first got my car, and same issue that Motortrend is facing in their long term car also. Last time, the remedy worked for a month then the squaking returned. Let's hope it works this time. |
12-31-2014, 02:35 AM | #17 |
32
Rep 105
Ugh. Same fix for the 1M charge pipes popping off I believe. Hopefully the F80 charge pipes dont explode like the plastic 1M charge pipes do, and hopefully somebody is already making aluminum charge pipes.
12-31-2014, 09:13 AM | #18 |
202
Rep 283
Ok,
Just got the downpipes installed and I am really really HAPPY. Honestly, I will not install an exhaust on the car. The car pops and crackles on over run and the turbos spool loud when driving Oh, and I managed to get a DSC light when shifting from 3rd to 4th... a first. I really like how the turbos spool now and like all the noises. My friend has an Akrapovic exhaust and this sounds actually better to my ears (of course I am biased, it is my car!!) I am uploading a video to Youtube at the moment.... As you can see, the valves were closed at the begining, even though I used Sport+, but they opened finally at 55 seconds into the video... then the turbo spool could be heard. This is just a teaser.... Last edited by uae247; 12-31-2014 at 12:10 PM.. |
12-31-2014, 09:28 AM | #20 | |
10817
Rep 27,600
nice looking forward to the vid! Do you have a decibel meter you could take a reading with?
12-31-2014, 11:51 AM | #22 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
It's interesting with all the people that have been to a drag strip how consistent these cars are. Usually there is a good bit of variation from car to car and even more so for a turbo, but these things are very close to eachother, which is great.
