12-03-2014, 06:03 PM | #1 |
57
Rep 477
Those of you with quad exhausts
Quick question guys those of you with custom quad exhausts, what is the part in the picture I attached? Do you guys remove it when doing a custom quad exhaust? I just bought my quad diffuser and looking at how to route the piping since my buddy is a welder that makes performance parts
FBO 09 135i Space Grey Metallic
///M Sport/Premium Package JB4 40% E85 / BMS Intakes / VRSF FMIC / Berk Resonated Midpipes / Custom Muffler Delete / N54 tuning downpipes / VMR v710 Wheels |
12-03-2014, 09:22 PM | #2 |
29
Rep 414
Take pictures of the setup once you're done, I've been wanting to go custom quad
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines.] |
12-04-2014, 06:29 AM | #3 |
1301
Rep 2,093
Drives: '11 135i M Sport
Take some better pictures underneath. I want to say it's possibly your charcoal filter. You may want to look into a 1M battery tray and charcoal filter relocation mod if you want to do the quad exhaust the right way.
12-04-2014, 01:25 PM | #4 |
57
Rep 477
I'll take some when I can, just wondering how people are using this exhaust then ? http://www.fiercespeed.com/18089-103...i-quad-tip.jpg
12-04-2014, 01:55 PM | #5 |
193
Rep 1,181
Ralph1M > That exhaust in the pic you referenced, is either designed or customized to fit the 135. It circles around the back of the battery tray. Yeineken > is correct. That is the charcoal filter. It is not/should not be removed.
On the 1M, it's relocated in order to properly fit the quad. I took some good before and after pics to give you an idea: http://www.1addicts.com/forums/showthread.php?t=1058189 Last edited by TUN3D; 12-05-2014 at 05:53 AM.. |
12-04-2014, 04:41 PM | #6 |
57
Rep 477
Well I have a 135i but in the picture I linked above, that charcoal box is not there which is why I was wondering how they managed to make it work, thanks for the info tho tun3d
12-05-2014, 07:42 AM | #8 |
137
Rep 952
False. Charcoal canister acts as a filter for fuel vapors. Keeping unwanted vapors/smells out of the environment, and the system reroutes fuel vapor to the intake manifold for emissions purposes.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
12-05-2014, 08:22 AM | #9 | |
57
Rep 477
12-05-2014, 08:23 AM | #10 |
57
Rep 477
12-05-2014, 08:41 AM | #12 |
193
Rep 1,181
Ralph1M > In that that pic BTW, I am about 99.9% sure the canister is there.
Here's a better pic: Here are similar setups: Like I mentioned, these are designed to go around the back of the battery tray & canister. The reason you don't see it is because there's a protective cover underneath. I'm not a big fan of removing stuff, so I would advise against it -- just me though. |
12-05-2014, 10:00 AM | #13 | |
29
Rep 414
12-05-2014, 11:28 AM | #14 | |
57
Rep 477
12-05-2014, 11:44 AM | #15 | |
1Addict
3234
Rep 7,894
Try ~550 USD depending on the daily exchange.
12-05-2014, 11:46 AM | #16 |
29
Rep 414
Am I mistaking for pounds? Lol
12-05-2014, 11:52 AM | #17 | |
29
Rep 414
12-05-2014, 12:04 PM | #18 |
172
Rep 2,347
Do you guys have A site? nvm found you on the gram, I need a quad exhaust
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
12-05-2014, 12:18 PM | #20 |
172
Rep 2,347
@tun3d which exhaust is this?
12-05-2014, 01:34 PM | #21 | |
193
Rep 1,181
After some digging around, that exhaust DOES NOT, appear to be a custom solution. It looks to be the "Arqray - Race Exhaust - e82 135i QuadTip" system. The post I found dates back to 2010 and couldn't find any current posts/offerings of the product. Most likely, its discontinued. These guys seem to carry it > fiercespeed.com. That said, because it's not/wasn't a custom solution, I strongly doubt that they (or any company for that matter) would require you to remove ANY mechanical component from the vehicle. From a liability standpoint, it doesn't make sense. Every single dual/quad exhaust setup that I've seen for the 135i does not require removal of mechanical components which are not directly related. The only mod that's common practice, is to cut/modify or remove the protective plastic piece that covers the entire bottom rear-right side including the canister. Some exhaust/diffuser combos bring the tips in more towards the middle. Others more towards the outside. Which diffuser did you get? Last edited by TUN3D; 12-05-2014 at 02:00 PM.. |
12-05-2014, 01:48 PM | #22 |
193
Rep 1,181
Zombie1 > Looks like that one is the 3D Design;
http://www.1addicts.com/forums/showthread.php?t=510186 I went directly to their site but don't see it in their offering any longer. |
