12-03-2014, 11:45 AM | #1 |
81
Rep 1,142
When to expect Single Turbo?
Are there any vendors or companies working on a single turbo manifold for the F80?
I'll be the first to say that only a top mount twin scroll setup would interest me |
12-03-2014, 12:06 PM | #2 | |
289
Rep 1,575
12-03-2014, 09:20 PM | #4 | ||
1003
Rep 3,051
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
12-04-2014, 01:23 PM | #5 |
8
Rep 330
Correct sir. Once the software exists the hardware isn't far off.
FFTEC 6466 6mt 335i | FFTEC GTX3076R Evo IX
12-05-2014, 10:22 PM | #6 |
81
Rep 1,142
12-05-2014, 10:54 PM | #7 | |
2712
Rep 2,371
Option 1: stick with stock dual turbos for very little lag, quickly spooling turbos with lots of useable hp and torque. Option 2: go with an overly large single turbo that takes a long time to spool, has lots of lag, and very little low end torque, but comes on with a huge amount of torque and HP around 4.5k rpms, resulting in massive wheel spin, but hey, you get to brag on the internet about how much HP at 7k rpms you have. I know which way I am going.
2015 Black Sapphire Metallic 6MT M4
12-05-2014, 10:59 PM | #8 | |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
12-06-2014, 03:41 AM | #9 | ||
289
Rep 1,575
12-06-2014, 08:55 AM | #10 |
81
Rep 1,142
It's apparent that you lack significant experience in driving an actual single turbo or twin scroll turbo BMW. So maybe you shouldn't make comments just to be "funny" it doesn't help anyone.
12-06-2014, 09:08 AM | #11 | |
2712
Rep 2,371
I'd have to say my comments do help some folks, just not the way you think they should help.
12-06-2014, 09:26 AM | #12 | |
81
Rep 1,142
Plus, none of those cars were a Twin Scroll.... so, totally irrelevant. |
12-06-2014, 09:58 AM | #14 |
Some dude
92
Rep 1,780
The N54 single turbos behave nothing like the Japanese single turbo garbage to which you refer. The S55 with a single turbo will be significantly more capable than the N54, PROVIDED the software can be put into place. Current encryption protocols are intentionally robust to prevent any form of tuning. I heard companies are going for copyrights on programming, so that any changes made to existing code would be a copyright violation. To get around it, you would need to 100% build your own code.
The N54 can be run single turbo with nothing more than a piggyback, but it works ideally with other changes that are best done in the ECU flash. Running the S55 on a single will more than likely require a similar setup. But don't be so quick to poo-poo the single turbo BMW inline 6. Criticism of the N54 single projects was identical, until dyno and real-world testing showed what a difference the extra air flow of the single really does. Check some of the e90post threads - this one was EARLY in the implementation stage, merely 16 to 22.5psi, third boost testing run. http://www.e90post.com/forums/showpo...71&postcount=1
RRT
E92 335i/6MT with stuff and things |
12-06-2014, 10:05 AM | #15 |
Some dude
92
Rep 1,780
Here is 700+ RWHP twin scroll single turbo, 500+ lb-ft of torque available from 4200 up to 7200 RPM.
http://www.e90post.com/forums/showpo...32&postcount=1 Not exactly the 800-1200HP dyno queen Supra numbers, but so much area under the curve that acceleration is just plain silly.
RRT
12-06-2014, 10:42 AM | #16 |
1383
Rep 3,834
One big twin scroll turbo would allow more boost/airflow. It's great for top end HP. You would only want this if you're building a car for high speed record, drag racing, and Dino bragging rights due to lag and burst of power at the top end. If you want to go fast around the corners, the factory turbos are good enough. Maybe someone will come out with 2 larger turbos instead, then it's the best of both worlds.
Our cars are only a few months old, I'm sure there is a HP race behind the scene for turbo manufacturers and reputable tuning shops. This is a solid engine, I can see it cranking out 1000hp+ like the fully built E46 M3 (HPF) with larger turbos or dual chargers. This should be easier since our tranny and diff are over built, came from the M5/6. If you have DC, they would need to figure out how to install grippier clutch to hold more than 600hp/600lb ft. Last edited by JNoSol; 12-07-2014 at 09:15 PM.. |
12-06-2014, 11:51 AM | #17 |
289
Rep 1,575
The e-turbos I suggested in my diy turbo upgrade might be perfect for aiding a single turbo application, imagine an electrically driven turbo in series with a large single, helping spool it up with preboosted air...
12-06-2014, 06:51 PM | #18 | |
649
Rep 4,323
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
12-06-2014, 07:45 PM | #19 | ||
81
Rep 1,142
12-06-2014, 09:14 PM | #20 |
253
Rep 551
12-06-2014, 09:18 PM | #21 | |
2712
Rep 2,371
I'll stick with my stock turbos, which build boost nice and fast and have max torque from 2k rpms. You go ahead with your dyno sheet bragging numbers.
12-06-2014, 09:55 PM | #22 |
81
Rep 1,142
I see your point, I really do. But I'm not talking about daily driving, if I was, then yes, the twins are awesome! But when talking about going with larger twins or a single turbo, it should be assumed that it's about winning on the track. People use these cars for other applications man.
