11-30-2014, 10:21 AM | #1 |
980
Rep 4,001
How Much HP/TQ is too much for DCT?
With the HP/TQ numbers these beasts are putting down and we all know this is just the beginning, How capable are the DCT trannies able to handle all this HP/TQ numbers on stock clutches safely on the track? I ordered my M4 DCT but I'm thinking about switching to manual.
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
11-30-2014, 10:36 AM | #2 |
21117
Rep 20,741
Drives: 2021 911 turbo
The DCT and differential were taken straight out of the F1X M5/6, so IMO it is safe to assume they can handle up to 600hp and 700Nm (516lb-ft) as they do in the M5 30 jahre special edition.
11-30-2014, 10:41 AM | #3 |
980
Rep 4,001
Are the clutch discs the same on both applications?
11-30-2014, 11:23 AM | #5 |
3169
Rep 2,135
I'm at 555 wheel tq, I heard the clutches begin slipping some point after 600.
11-30-2014, 11:31 AM | #6 |
352
Rep 2,176
No problems with slippage for me even on track with a tuned full bolt on M6 CP making over 6xxwhp/ 6xxtq . The DCT can handle anything the S55 can throw at it with stock internals.
11-30-2014, 11:41 AM | #7 | |
980
Rep 4,001
11-30-2014, 11:42 AM | #8 | |
980
Rep 4,001
11-30-2014, 03:26 PM | #9 | |
469
Rep 4,392
Since the N54 and S65 DCT can handle 850-900 nm flash tuned only, then when we are able to flash tune successfully the M4/M3 DME then I am 100% possitively sure we'll see 900-1000nm safely out of it before any type of slippage starts to occur |
11-30-2014, 03:50 PM | #10 | |
980
Rep 4,001
11-30-2014, 04:01 PM | #11 | ||
352
Rep 2,176
11-30-2014, 04:54 PM | #12 | ||
469
Rep 4,392
Per Steve Dinan himself: starting at 0:29 A piggyback offsets the signals to the DME in which the DME is communicating its "flash" based calibrated stock algorithm back to the trasnmission's TCU. What this means in reality the TCU is not getting the proper and correct load to torque calculations to apply the proper bar presure to the clutches to avoid slippage "up to a torque output certain point" All piggyback manafactures will tune to the point where things become unstable or slippage starts to occur and then back off to a certain point depending on the tuner. Dinan is much much more conservative when it comes to this when compared to BMS JB4 Flash tuning allows absolutely accuracy and proper load to torque reporting by the DME to the TCU to be able to achieve more torque with less risk of slippage. The same exact folklore started with the conjecture on the N54/S65 DCT with "a certain unmentioned" company and its followers started spewing about the DCT limitations and were proven wrong as the limitation was based on their on method tuning when there was "no backend flash" available Being that they were able to NOW achieve 550 wtq on "ugpraded turbos" from what was underated by almost 60 wtq before introducing flash as a suppliment to piggyback tuning. Still to this very day flash only on merely stock turbos is able to achieve higher wtq on the N54/S65 "DCT" over the piggyback and the piggyback + back end flash suppliment |
11-30-2014, 09:55 PM | #14 | |||
352
Rep 2,176
11-30-2014, 10:32 PM | #15 | |
3169
Rep 2,135
12-01-2014, 03:52 AM | #16 | ||
352
Rep 2,176
12-01-2014, 07:37 AM | #18 |
92
Rep 102
12-01-2014, 08:18 AM | #20 | |
980
Rep 4,001
12-01-2014, 08:40 AM | #22 |
980
Rep 4,001
I know right, decisions decisions
