11-26-2014, 04:42 PM | #1 |
432
Rep 1,024
H&R Street Coilovers
Is anyone currently running this setup on their car? Or previously had it?
I did a search but couldnt really find anything. Thanks |
12-04-2014, 01:18 PM | #3 |
123
Rep 374
I have a set on right now. Been on my car since April. Got it on clearance from Turner $999 out the door if I remember correctly.
I'd say they're good for what I use them for which is daily driving with some aggressive driving here and there (ie long freeway transitions, on-ramps, etc.) My car is never going to see track and I didn't need any other type of adjustability so I went with these. At the time KW V1 wasn't out yet. The only kind of negative I have is the fronts won't go any lower. At its lowest setting, the top of the fender is even with the top of the tire. I was hoping it would tuck just a little more. My mechanic who installed them said the rear still had a little more left to go lower. However, he corner weighted the whole car and I specifically told him I didn't want any rake. I measured the ride height at the little rubber pieces used to jack up the car and the rear was about 1/2 inch higher than the front. I figure it evens out with passengers in the car. Hope this helps! |
