11-25-2014, 02:55 PM | #1 |
29
Rep 243
JB4 with torque app
Has anyone with jb4 (stage 1) used the torque app with a bt dongle to get a boost reading? I have tried to get boost reading with jb4 on map 1 but for some reason it shows only 18 to 19 psi peak boost. I am pretty sure I am doing something wrong as i can feel the car pull much harder vs stock. Can someone with torque app shed some light in the boost settings that need to be in place for the correct measurement.
11-25-2014, 03:54 PM | #2 | |
329
Rep 984
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
11-25-2014, 05:02 PM | #3 |
29
Rep 243
Isnt the stage one suppose to be 21-22 psi? Also with the jb4 would the ecu see register the higher boost or would it still show stock boost if i tap into the boost channel thru torque app?
11-25-2014, 05:39 PM | #4 |
329
Rep 984
Good point, if you don't have CAN setup through the JB4 you can't monitor boost, and no the car still thinks it is stock levels.
11-25-2014, 05:54 PM | #5 |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
Awron display shows accurate boost readings:
We're using one currently with the JB4.
11-25-2014, 06:23 PM | #6 |
Joint Chiefs of Staff
4918
Rep 115,980
The DME will only see stock boost with a JB4 in place. You'd need the JB4 mobile software to monitor boost on an iPhone, Android, etc.
Gauges like the AWRON that have an external boost input can also monitor actual boost but be careful to disable any CAN features on these gauges OR only use the JB4 as Stage1 as both using the CANbus will prevent the JB4 from working properly. Mike |
11-25-2014, 06:26 PM | #7 | |
8215
Rep 18,823
Drives: BMW
We have both devices running perfectly on our shop M4.
11-26-2014, 10:47 AM | #8 | |
4918
Rep 115,980
Mike |
08-17-2015, 08:11 PM | #9 |
180
Rep 97
Any new developments with the Awron and JB4 compatibility issue? I just had JB4+ installed on my M4 which already had Awron hooked up. My JB4 has the new OBDII port connection... Do I need to be concerned with them not playing well together?
08-18-2015, 01:10 AM | #10 | ||
231
Rep 656
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars | |
08-18-2015, 02:56 AM | #11 |
8215
Rep 18,823
Drives: BMW
Awron has dropped support for JB4, sorry.
