11-23-2014, 05:12 PM | #1 |
1164
Rep 451
Supersprint MAHA dyno; 471 PS
471 PS on Supersprint's MAHA dyno with room temperature sprayed water on the radiator and intercooler.
Quite the underrating by BMW. |
11-24-2014, 10:12 AM | #3 |
21117
Rep 20,741
Drives: 2021 911 turbo
This is consistent with the 465ps that Sport Auto obtained on their Maha dyno run.
40ps more than the official rating, pretty good |
11-24-2014, 11:56 AM | #4 | ||
1718
Rep 5,110
Also agree that it's quite consistent with the Sport Auto Supertest dyno. However, just to add some context to even MAHA dyno results... Quote:
11-24-2014, 12:31 PM | #5 | |
21117
Rep 20,741
Further, the shape of the power curve obtained on Maha is much closer to the one published by BMW compared to the one from Insoric. I've said it many times, validating how accurate (or innacurate) a dyno is has to do with more than just the the peak power number. At which RPM the peak is produced and the overall shape of the curve are just as important. |
11-24-2014, 01:13 PM | #6 |
5457
Rep 7,037
Sounds just about right. You will never get rid of the arguments against this level of under rating since there is no perfect methodology or environment that matches all conditions but for me the case has been closed for months. Relative to how cars are usually rated by buyers this is the level of hp the car makes. Thanks for sharing.
11-24-2014, 01:27 PM | #7 | |
1718
Rep 5,110
I agree that just looking at two dyno sheets and compare them is meaningless. However in this case we have context! Or did you not see how the acceleration times compared? That was IMO, the whole point in my post. Not which dyno was correct, but that the car with the highest dyno numbers was slower than the car with lower dyno numbers... And in fact, the acceleration times was as they should be! A M5 30 Jahre with 600hp should be faster than the M5 CP with 575hp. So in every aspect, apart from the dyno results, the two cars act like two cars with different power output. In the real world the stronger car is faster! On the dyno the slower/weaker car has more HP... So, on the dyno, the real world test results, and BMW's claimed power ratings, are turned upside down... And in that context the dyno numbers don't add up (regardless of which dyno one prefer to believe). My point wasn't about over- or underrating, but about dynos not being a very reliable comparison tool without a fair amount of scepticism. My point was about validating the relative dyno numbers with real world acceleration tests and see how they compared. |
11-24-2014, 02:18 PM | #8 | ||
21117
Rep 20,741
If your point is that both are innacurate, then we are in agreement . |
11-24-2014, 03:07 PM | #9 | ||
1718
Rep 5,110
But, I did write the following as a closing remark in the post: Quote:
11-25-2014, 02:54 PM | #10 |
82
Rep 2,688
Personnaly, I believe that crank hp ratings from Maha dynos are very accurate.
Me and some friends have rented a Maha dyno at Lachute Performance two weeks ago to do a little friendly shootout and the whp ratings for all our cars were pretty low(which was to be expected) but the crank hp ratings seemed pretty spot on IMO, specially looking at my friend's stock C63 507 that made 510bhp which is exactly where it should be. Here's some of the results for those interested(all cars on 94 octane): -C7 Stingray manual, Corsa Sport valve-back exhaust and Green Performance drop in filter -C63 507 stock -E92 M3 manual, ESS VT1-550 and Turner test pipes |
11-26-2014, 03:08 AM | #11 |
Rep 84
Hi guys.
I was there when Supersprint tested the F82 M4, as well as many other tests. Here are a few considerations: 1) Supersprint has a custom water spray system for the intercooler. While less relevant on the m4 F82 / M3 F80 (and the M5 F10 as well) because of the air/water system compared to a air/air traditional intercooler, it does make a difference as it increases the heat exchange on the radiators surface. Basically it emulates the perfect conditions even when the dyno room is hot 2) Maha itself has recommended to NOT use the EWG or DIN correction factor when testing turbo cars. This is because even if the ambient temperature, humidity and pressure are not adequate to get the best performance, the turbocharger and intercooler will make the air going into the engine basically spot on all the time, unless it's overheating but the water spray system takes care of that. This is the reason why if you check the latest dyno testing on the SS website you'll see the NA and supercharged cars have the EWG correction factor applied, the turbo cars not. Here's a sample of a turbo car, Mini F56: Here's a sample of a NA car, GT86: The Insorit system, as well as other similar systems based on GPS, accelerometers and car specs, work pretty well for in-gear acceleration figures, less so in accelerations from still because the tyre slip must be taken into account. Also, the mass of the car must be measured accurately with scales before the testing, including the driver and fuel. These systems are more useful to check power gains than absolute figures. You can use the system, for example, before and after a remap. As you use the exact same values (weight, tyre size etc) and the car is the same, the difference before and after will be pretty accurate. |
11-26-2014, 08:39 AM | #12 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
I should have another MAHA dyno result for my F82 by the end of the day. I've already had my car dynoed on a DynoDynamics, but I've found the MAHA to be very accurate in other cars I've had in the past and I'm just anal. I'll be using this as my pre Dinan Stage 1 baseline which will be installed next week.
They usually ask me if I want crank or wheel numbers, I'll ask for both.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
11-26-2014, 08:46 AM | #13 | |
592
Rep 5,396
11-26-2014, 09:03 AM | #14 | |
21117
Rep 20,741
11-26-2014, 05:32 PM | #15 |
1231
Rep 1,789
Drives: wife crazy
441.2 crank hp, 356-371 whp today on the MAHA. My car has already dynoed 415 whp on a DynoDynamics, so I think this more or less underscores how different dyno machines can be. I'm really looking at deltas for my Dinan tune next week. I may have the car done at both places after the tune. My car does not feel any less powerful.
The real measurement will be my lap times this weekend. I'll be doing the same track for the second time in the F82, so we'll see.
11-26-2014, 05:48 PM | #16 | |
82
Rep 2,688
Very interested in seeing your dyno post Dinan! |
11-26-2014, 08:16 PM | #17 |
9
Rep 158
Here's a teaser of the Alekshop M4 Maha results in California. On the first run, we hit 480 crank horsepower at part throttle. Since this was the first run, it was part throttle until about 6000 RPMs, and that's probably why the torque curve doesn't look like normal. On the second run, we had nearly 40 more horsepower at 6000 RPMs, but had to cut the run short. We will have a full write up in a few days.
12-04-2014, 06:47 PM | #18 |
82
Rep 2,688
12-05-2014, 07:29 AM | #19 | |
1718
Rep 5,110
And, MAHA recommends NOT using the correction on these cars since the DME "autocorrects". By using the dyno correction on top of that you actually get a double dipping... Your car actually makes EXACTLY the HP number as stated by BMW... But made 415rwhp on a Dyno Dynamics! Hmmmm... The second run, was that done with the MAHA in "RWHP mode"? I noticed that RWHP is diifferent than from the other dyno run. |
12-05-2014, 08:00 AM | #20 | |
592
Rep 5,396
12-05-2014, 01:02 PM | #21 |
1718
Rep 5,110
12-10-2014, 10:12 PM | #22 |
1231
Rep 1,789
Drives: wife crazy
Dinan tune in, but there appears to be an issue with the post tune dyno testing. I'll post more when I get more info, sorry.
