11-22-2014, 07:48 PM | #1 |
185
Rep 792
F82 M4 Bone Stock 413whp Verse Bms Only, 535whp
Well finally got my M4 broke in and took her for her base dyno runs before I start product development as well as BMS JB4.
First pulls 93 octane 413WHP 420WTRQ Raised the boost to MAP 1 470WHP 488WTRQ Next raised the boost to MAP 2 as I logged and sent them to Terry to check everything. Looking good but not much gains other than torque. This MAP mostly for e30 E85/93 mix. 466WHP 505WTRQ So I kept it at MAP 2 filled her up with e30 E85/93 mix and ran her for a couple of days till she adapted. Went through a whole tank of gas and refilled as I headed for some more testing. Same MAP2 with e30 E85/93 mix, car gained some great power 494WHP 511WTRQ So here we go again raised the boost to MAP 7 while I logged and sent to Terry. So far so good with some great gains even though hasn't adapted. 535WHP 532WTRQ. Not bad considering no adaptaion just doing a couple runs on the dyno. As I went out for dinner did some adaptation pulls, stopped a couple places for some ignition turns and as the night progressed the car got stronger. I couldn't drive the first 3 gears without having traction issues. Burning 3rd gear at 60 MPH was a reality. By the time I got home I was burning 4th gear at 80 MPH and temps were 45-55F. Crazy!!!! I bet she gained another 20-30WHP since the earlier dyno pulls. Going back next week to see if she made anymore gains since the adaptation process. Then will do some more fuel tests, 100 octane and then 109 to see how much power she will get before I start product development. I swear this car probably will get 580-600 WHP with 109 octane before any mods touch her. All I can say is great job Terry she's a beast. Looks like she'll be right there in the 10's like my M6. I'll keep you guys in the loop as I continue test other fuels and map. Thanks again Terry for all your help and awesome products with that great customer service you provide. You the man! Last edited by m6beast; 11-26-2014 at 05:03 PM.. |
11-22-2014, 09:04 PM | #3 |
185
Rep 792
You run the car a couple times in a third gear pull then park and arm it. As the days progress do a couple 4th gear pulls and do the same park and arm. The adaptation process takes lots of long gear pulls for example 3rd or 4th and ignition turns meaning turn the car off arming it and letting it sit for a while. The best way is start your morning on your way to work or where ever,do some pulls then park, on your way to lunch do the same. Then on your way back do the same . Then when you leave work same thing. As the day progresses you'll start to notice how strong she's running. Remember it's a piggy back not a tune so the DME will make adjustments through every pull and in sleep mode.
You ever run your car at the track? The car always feels stonger the very next day do to running it hard and turning it off and on through out the day Hope that makes sence. Last edited by m6beast; 11-22-2014 at 09:37 PM.. |
11-22-2014, 09:55 PM | #5 |
185
Rep 792
11-22-2014, 10:50 PM | #7 |
848
Rep 3,249
THIS, except I think drew meant "without"
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
11-22-2014, 10:54 PM | #8 | |
185
Rep 792
Once I build the the full catless DP and straight through exhaust with resonators and my custom intake you'll see over 600 WHP with 109 octane. I do real testing and data not an opinion. Dyno Vbox track and racing to get the best setup. Tell me is it possible for an M6 to make 670whp and run 10.7 129 mph? I guess we will find out if you're right |
11-22-2014, 10:54 PM | #9 |
3169
Rep 2,135
What's the difference in map 7 and 8, is 8 just the meth variant?
11-22-2014, 11:02 PM | #10 | |
848
Rep 3,249
11-22-2014, 11:03 PM | #11 |
848
Rep 3,249
8 is the meth map. 7 is the race fuel/aggressive map.
11-22-2014, 11:04 PM | #12 | |
185
Rep 792
After another base with adaptation will add 100 octane and go back and Dyno log and work with Terry on any adjustments needed. After that will burn all the 100 then add 109 and go Dyno again for more adjustments . All in time, I'm trying to get every bit of horsepower just in tuning before my catless DPs, exhaust and intake are added. All this info is to help you guys see what's the best setup for this car in map and fuel settings.So for those who hating you can relax a bit till all the tests are done. |
11-22-2014, 11:06 PM | #13 | |
289
Rep 1,575
11-22-2014, 11:06 PM | #14 | |
848
Rep 3,249
11-22-2014, 11:10 PM | #15 |
185
Rep 792
11-22-2014, 11:19 PM | #17 |
848
Rep 3,249
Very similar process. Dyno time, changing fuels, changing maps, sending logs and updates back and forth with terry and even having him look at my logs in person. I've done plenty of Mexico pulls, but also went to NFZ last weekend and it had plenty of adaptation. I have a full exhaust and catless DPS, and run 100 daily. I used 109 and Map 7 at NFZ and was the highest trapping S55 car there. Straight from Terry's mouth, the cars are limited on power because of the turbos' size. I guarantee you will not see over 600whp on stock turbos.
There is a stage 2 solution coming out for the turbos here very soon, so keep your eyes out for that. That's all I'll say for now about those.
11-22-2014, 11:23 PM | #18 | |
289
Rep 1,575
Also I'm glad you're educating ppl about the BMS tune adaptation process because I feel that is what a lot of customers fail to understand. They switch maps and allow zero time for adaptation before they go measuring the power, either by racing or by dyno...then they complain about drivability, smoothness, power etc. |
11-22-2014, 11:26 PM | #19 | |
185
Rep 792
That's real data. And my custom intake has proven it in every test. No worries man I knew I made a mistake of telling what I feel the car will gain with fuel an adaptation. I speak from experience and how a car feels and testing. So from now on I'll just bring the dynos to back it up. It's all good I've been down that road before with my M6 and here I am first M6 to be in the 10's. All that came from testing and product development so I'm here giving back to you guys my feed back ect. |
11-22-2014, 11:34 PM | #20 |
3169
Rep 2,135
Thanks. Was just making sure I wasn't missing out on map 8, I thought it was a meth map but wanted to verify. I daily map 7 with 100.
11-22-2014, 11:34 PM | #21 | |
848
Rep 3,249
11-22-2014, 11:36 PM | #22 |
848
Rep 3,249
Honestly, that's the best combo IMO right now. 109 helps, but for the price of 109 vs. 100, 100 is a better bargain for similar performance. Be safe out there!
