11-19-2014, 10:09 PM | #1 |
123
Rep 353
OEM exhaust mod plus valve flaps open
I removed the connection to the valves last week. Car sounds a lot beefier below 3000rpm. Not much louder to be honest but a lot deeper at lower RPM. Should have come from the factory this way. Sounds like a 4.0L I6 instead of a 3 liter if you know what I mean.
Regardless of aftermarket exhaust, none of them seem too appealing to me. Turbos have really taken the fun out of that. I'd rather have the perforated pipes changed with solid pipes again on this model. Anyone do this yet, and did the exhaust get noticeably louder? I know the valve allows the gases to exit directly, but half the gases are still flowing through the center exhaust. Any incite would be appreciated. Please spare me the merits of purchasing an aftermarket exhaust vs doing this. |
11-19-2014, 10:52 PM | #3 | |
123
Rep 353
Oh, before you begin grab your iPhone and shine the light into the tailpipe. Make sure the valves are open! If it is closed, it will stay closed after you disconnect it. I did it first with the valves closed and it was quiet. Had to reconnect the valves and redo it a second time. Takes 10 minutes to do both sides the first time, not even 5 the second time. |
11-19-2014, 10:53 PM | #4 | |
14
Rep 221
11-19-2014, 11:06 PM | #5 | ||
56
Rep 340
11-19-2014, 11:12 PM | #6 |
123
Rep 353
No problem. You see the top of the connection where there that plastic tab is? Place the flat head bit in-between. You can you feel with your finger where the tab flexes upwards. Then pull hard while holding the top and bottom of it with your fingers. Will be easy the second time you do it.
11-20-2014, 10:40 AM | #9 | |
14
Rep 221
11-20-2014, 12:30 PM | #10 | |
56
Rep 340
Thanks again ! |
11-20-2014, 01:35 PM | #11 | ||
34
Rep 110
11-20-2014, 01:42 PM | #12 |
410
Rep 1,025
I tried unsuccessfully to get them off last week and ended up shredding my hands in the process. It's very tricky to get to without the car lifted because it's a very tight space, and the edges of the underbody shielding are very sharp, so watch out. I'm going to try again, but with gloves this time!
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
11-21-2014, 02:38 PM | #14 |
118
Rep 287
there wont be an error code on the dash but it will save an error code in the system that the valve system is not working ... had the same on my Z4. Just unplug it ..
11-21-2014, 10:10 PM | #15 |
167
Rep 117
did it last night , made a HUGE difference in cold start in a good way , i think the tip is to actually to use your fingernail and press the small rectangular piece and then pull with the other hand
11-21-2014, 10:33 PM | #16 | |
13
Rep 85
Mavs1balla154.50 |
11-22-2014, 10:23 AM | #18 |
123
Rep 353
Just listened to video comparing the OEM exhaust with the M Performance one. Here: http://f80.bimmerpost.com/forums/sho....php?t=1061040
1st is OEM with valves closed, 2nd is OEM with valves open, 3rd is MPE with valves closed, and 4th is MPE with valves open. As you can see the sound signature is similar across the board for the two exhaust, but as you listen to the four different exhaust sounds it becomes more raspy and angry sounding. I think doing the perforated exhaust mod to decrease sound reduction for half the gases flowing into the center exhaust we will end up with a sound identical to the performance exhaust. We just need a guinea pig to volunteer to do it. Anyone up for it? Would be nice to hear. EDIT: Btw, the cold start up is LOUD with the open valve mod done. Louder than the E9x M3 with the exhaust mod. |
11-22-2014, 12:28 PM | #19 |
439
Rep 1,732
I just completed this mod. Cold start is so much louder. Even when warmed up it is still louder than with valves closed. I found it a bit tricky getting the right hand side plug removed but other than that it is well worth the time.
11-23-2014, 04:54 PM | #21 |
30
Rep 173
Pumped! Didn't know this mod existed until I read this thread tonight.
Ran out to the garage a few minutes ago and knocked this out in about 25 minutes (including electrical taping and wire-tying things up). Just started it up and it sounds awesome. You can cycle through the M1 and M2 maps and now there is no difference in exhaust note - even from Efficient mode to M2. Very pleased. Now to take it for a longer spin and check for drone. Super excited so far. Thanks for the writeup!
2019 GT3 RS
