11-19-2014, 08:34 PM | #1 |
Senior Chief Petty Officer USN
106
Rep 501
What is a backend flash?
I see people talking about this and I'm curious as to what it is and how it works. I'm currently running JB4 ISO. Have berk exhaust and no other mods.
Thanks |
11-20-2014, 12:14 AM | #2 |
171
Rep 2,682
A backend flash is an ECU flash tune designed to generally control fueling and timing amongst other things, leaving the piggyback to control boost, maybe some fueling and maybe some meth. It is necessary when wanting to run higher concentrations of ethanol as the stock DME fuel scalars were designed to run only petroleum or very low ethanol blends.
In my case, I have a Cobb backend flash which controls fueling, AFRs, timing etc. My Procede controls the boost and methanol.
11-20-2014, 02:10 PM | #4 |
106
Rep 501
11-20-2014, 02:34 PM | #5 |
13
Rep 113
as far as I have been led to understand map 0 the ppk will still be functional as the jb4 is essentially off, after that it will nullify the PPK
11-20-2014, 02:35 PM | #6 | |
106
Rep 501
11-20-2014, 10:43 PM | #7 |
18
Rep 205
Good description above. That was my understanding as well. But it would be great if someone could elaborate and explain what types of setups would benefit most or not benefit, i.e, turbo upgrades or Cali 91 octane.
I see people making great power using this "best of both worlds" set up, but since it's new there's not a lot out there to research yet.
[SIZE="1"]JB4 ISO, PURE Turbo Stage 1 v2, Megan DP, 5" stepped VRSF FMIC, AFE CAI, Fuel-it Stage 1 inline LPFP, ER Charge Pipe, KWV3 w/swift spring conversion, M3 Front Control Arms, e90 M3 FSB, Whiteline RSF Inserts, Dinan Camber Plates
11-21-2014, 07:33 AM | #8 |
555
Rep 735
Not new. I've been using a BMS flash for years and I'm never an early adopter of anything. Search around. There's a sticky on n54tech that is like 100 pages all about it.
11-21-2014, 07:51 AM | #9 |
188
Rep 2,225
IMO its not worth it until you have full bolt ons and/or are using E85, or if you have done a turbo swap.
My plan is full bolt ons, then the pump gas backend flash when that is no longer good enough. |
11-21-2014, 08:17 AM | #10 |
1Addict
3234
Rep 7,894
Maybe not for power, though it has been demonstrated (by Terry) to produce more even on a car with limited mods. What it does is introduce the smoothness of a flash tune coupled with the features and adaptation of the JB4.
11-21-2014, 09:54 AM | #11 |
193
Rep 1,181
+1 > froop
The JB4 can only take you so far. As you push more power and/or start using meth/e85...the fuel demands change. These changes can not be dialed in properly thru the JB4. While there are added benefits to the back-end flash, the most important aspect is fueling. Once your car is flashed, the JB4 (or Procede in froop's case), is used primarily to change maps/control boost. Everything else is dialed right into the DME. Even though the JB4 can handle things fairly well, including meth & some E85, you can use a back-end flash at any time. If you're using one of the FREE solutions out there, just make sure you get the right one according to what you're running and what version of the DME you have. If you're a casual enthusiast -- just run the JB4 with a little E85 (maybe a little meth) and you're golden. Forget the flash. If you're a power hungry enthusiast...the rule of thumb is to work your way up gradually and log-log-log. The numbers will tell you what to do. Last edited by TUN3D; 11-21-2014 at 10:02 AM.. |
11-21-2014, 10:11 AM | #12 | |
61
Rep 722
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
11-21-2014, 10:18 AM | #13 |
18
Rep 205
Thanks guys. This is helpful. I had read that thread but not the newer posts. I'll revisit it. My confusion came when I saw the big power gains on pump gas, but then someone "associated" with BMS said that it was only recommended for turbo upgrades (which makes sense, power-wise).
I have most power mods (minus fmic on the way) but am limited by 91 octane. I mix in 4 gallons of e85 and am very happy with the power, but since it's natural to want more eventually wanted to know my options for increased power and smoother delivery. Not really thinking about meth (yet) and not going to upgrade turbo because I have a lot of suspension work ahead that I'd want first. Last edited by 1forI; 11-21-2014 at 10:28 AM.. |
11-21-2014, 11:27 AM | #14 |
193
Rep 1,181
1forI > The notion that the flash is "only" for upgrades or power-gains is a little misleading.
For my current build, as an example, I'm not running upgraded snails...or meth. My city has 93 & e85 all over the place. The JB4 alone can handle about 3-5 gallons of e85 before it shits all over itself. Meaning...runs way too lean, error codes, limp mode, etc. This happens because the fuel adjustment scale of the JB4 is limited. You also can't adjust timing properly to compensate for the higher octane levels produced by blending gases/adding meth. That's where the flash comes in. It doesn't produce any more power per say (again, if used in conjunction with a piggy-back). It simply switches the basic fueling/timing responsibilities over to the DME where there is unlimited room for adjustments. In your case, with 91 & 4-gals of e85 -- you're fine. In contrast, I run 93 & 9.5-gals of e85 -- that's why I have to use it. Meth will defiantly help you in terms of raising your octane levels (not to mention the added cooling benefits). That said though, being that your on 91, you still have some room to play with. Try adding 5-gals of e85 and see how your car does. Log and post the results on n54tech.com. If it does well, try 6-gals -- rinse and repeat. The idea is to push it gradually and find the threshold of what your car can handle on the JB4 alone. As soon as you hit the wall (which your car will tell you BTW), just scale it down gradually -- find the sweet spot -- to where it runs well. Once you get there (and perhaps want to keep climbing)...that's when you'll need to evaluate the situation and decide on a flash, upgraded LPFP, etc. Last edited by TUN3D; 11-21-2014 at 04:42 PM.. |
11-21-2014, 02:05 PM | #16 |
61
Rep 722
If you have an e85 backend flash do you always have to run e85 once you have it flashed?
11-21-2014, 02:16 PM | #17 | |
1Addict
3234
Rep 7,894
If you don't have it and hit boost repeatedly as normal, you will run super lean, errors, and maybe damage something.
11-21-2014, 04:03 PM | #18 | |
61
Rep 722
11-21-2014, 06:53 PM | #19 |
1Addict
3234
Rep 7,894
yup, upgraded fueling is a prerequisite.
11-22-2014, 08:21 PM | #20 | |
Joint Chiefs of Staff
24199
Rep 190,807
But the PPK will still control AFR,ignition advance and fuel
11-24-2014, 12:27 PM | #21 |
188
Rep 2,225
