11-18-2014, 10:56 PM | #1 |
256
Rep 769
Major differences between S55 and N54/55
I wasn't sure which section to put this in but felt the general tab was my best bet. I'm taking delivery of my M4 this thursday and I'm more than excited. I just can;t help to ask, what are the major differences between the s55 used in the M3/4 vs the N54/55 used in the M235i, 335i, etc. Im coming from an e92 M3 which was a whole different engine altogether so its interesting to me. What really is the difference between these motors. Thanks in advanced guys.
11-18-2014, 11:06 PM | #2 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
11-18-2014, 11:08 PM | #3 |
499
Rep 2,400
You should check out the BMW Sales Training/Tech guide for the M3/M4. It does a side by side comparison between the S55 and N55 in all relevant aspects. Pretty interesting reading.
11-18-2014, 11:13 PM | #4 |
256
Rep 769
I just looked at the tech guideline that the previous poster had posted but can't find this side by side comparison
11-18-2014, 11:17 PM | #5 |
10785
Rep 8,852
It is in the second document
11-18-2014, 11:25 PM | #6 |
256
Rep 769
Great! found it... thanks sakhir. It seems like the n54 and s55 are very similar. Would anyone happen to know what turbochargers are used between the two and if these are different? Its interesting that the n54 and s55 sound completely different even though they're so similar.
11-18-2014, 11:40 PM | #7 |
10785
Rep 8,852
11-18-2014, 11:43 PM | #8 | |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
11-19-2014, 01:22 AM | #9 |
726
Rep 1,974
Simple, N54 sounds way better than N55 or S55 lol.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
11-19-2014, 02:56 AM | #10 |
978
Rep 2,124
Both are great motors indeed and will be legends in their own class. Still in break in for the s55 so can't really compare yet to the N54, which pulls like a raped ape with current mods..
15 F82 M4,YMB-6MT
17 G30 540i,AW-8spd ZF 24 G82 M4C x-drive, DY-Dakar Yellow ind-8spd ZF |
11-19-2014, 06:02 AM | #11 |
10163
Rep 8,626
The current big advantage that the N54 has is a decrypted and translated ECU that allows full freedom for flashing. Virtually everything else goes to the S55... everything. Better cooling, larger turbos, closed deck block, higher rpm... I could keep going for a day but the true capability of the S55 won't even be explored until a full flashing solution is offered.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
11-19-2014, 06:36 AM | #12 | |
21117
Rep 20,741
Drives: 2021 911 turbo
A tidbit a found interresting, is that it seems that they went back to a mechanical main pump for the engine cooling circuit on the S55. The N55 has an electrical pump. Last edited by CanAutM3; 11-19-2014 at 09:38 AM.. |
11-19-2014, 06:59 AM | #13 |
Enjoying driving
388
Rep 1,169
11-19-2014, 08:20 AM | #14 | |
172
Rep 894
Drives: 2011 Toyota 4Runner Trail
For example, he said the S55 was mostly a dry sump. I'm not sure what he means by that nor am I sure that the S55 actually has a dry sump. |
11-19-2014, 09:05 AM | #15 | |
72
Rep 234
Basically here is nothing similar to the two engine classes with the exception of the nominal displacement of 3 liters. But note that the actual displacement is not the same either.
Closed deck block Larger bore Shorter stroke Arc spray cylinder liners Forged crankshaft Completely different turbo philosophy and design(N55 uses a single twin scroll while the S55 uses twin single scroll) Etc., etc.. Basically there is nothing the same, and anyone that tells you different simply doesn't know anything about the two engines. Quote:
11-19-2014, 09:47 AM | #16 | |
172
Rep 894
No one is claiming that the N54 is the same engine as the S55 or that it offers the same performance. But it did serve as the basis for the S55. |
11-19-2014, 10:05 AM | #17 |
1796
Rep 2,997
I would bet on the longevity of the S55 and powertrain components being better. Not only from ~7 years of learning by BMW, but because:
1. They reduced the oil change interval from 15k to 10k on ALL Bmw turbo engines effective on 2014 model years (lessons learned I guess) 2. The cooling of the S55 is ridiculous. The N54, from the factory and with the factory oil coolers, still had high degrees of oil temp fluctuation in aggressive everyday driving and definitely on the track. The S55 is far better in this regard, which I think is going to translate to better turbo life (among other things) This is besides those technical differences mentioned
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
11-19-2014, 10:17 AM | #18 | |
196
Rep 1,248
Just adding some facts to the revisionist history that goes on around here. Too many people who've never had grease in their hands think displacement is what defines engines. Last edited by Carl L; 11-19-2014 at 10:26 AM.. |
11-20-2014, 07:01 PM | #19 |
61
Rep 776
11-20-2014, 07:03 PM | #20 |
61
Rep 776
paulo_f80m3559.00 |
11-20-2014, 07:29 PM | #21 | |
21117
Rep 20,741
11-20-2014, 07:34 PM | #22 |
21117
Rep 20,741
