11-17-2014, 06:37 AM | #1 |
Rep 28
Cranks, won't start w/o jump. RPMs bouncing
Not my video but my car started doing the same thing. Took it to BMW and they told me it was my throttle body. After some research, I saw that throttle body failure caused similar issues so I went ahead and ordered the part. Yesterday I swapped it out but nothing changed. Hopefully someone here has fixed this problem before. Thanks |
11-17-2014, 07:37 AM | #2 |
FOUO
415
Rep 873
im not able to watch the video, but maybe it's a dead crankshaft position sensor? i had the same issue awhile back.. it wasn't dead, but faulty, so the car would start, but while idling, it would sometimes stall on me randomly, and some crazy misfires.
11-17-2014, 08:05 AM | #3 |
Rep 28
No misfires yet. As soon as the engine does start, the needle steadily bounces as the the engine revs itself. CEL, traction, brake and limp mode all come on and when driving, it has no power and can't get above 3000 rpm
11-17-2014, 09:40 AM | #4 |
81
Rep 1,051
You always need to read codes with at least an OBD2 compatible reader when asking for advice with issues with your car. Even if it is just to say you tried with X brand scanner and found no codes, but I very much doubt you have no codes.
Codes can help narrow the issue down from hundreds of possibilities to a handful. A vast majority of trouble codes that cause acute issues spell out exactly which sensors or motors are the problem. There's no reason to continue troubleshooting without an OBD2 read.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
11-17-2014, 10:10 AM | #5 |
Rep 28
Didn't say I didn't have codes. I said I didnt have misfires. I attached 2 crappy photos from my JB4. My gut is telling me its the battery thats screwing everything up but BMW insists that if it cranks then its not.
11-17-2014, 10:37 AM | #6 |
81
Rep 1,051
Looks like p2a9a and p2a9b are VANOS related, probably solenoids since that seems a somewhat common issue.
My guess on the fuel pressure ones are either they are a byproduct of you cranking the engine repeatedly, or in combination with other unrelated codes you have a bad ground which is causing many issues. Have you replaced the battery recently, or done any other work where an engine ground may have been disconnected? Audio equipment installs? Since you seem to crank ok I'm not sure the battery is actually bad, but it is possible. A bad ground in a specific spot where some sensors get their ground seems more likely to me, and I've seen this happen several times on different brand cars. Several sensors that pick up ground from a specific spot with a bad connection will all pop CEL codes.
11-17-2014, 11:10 AM | #7 | |
Rep 28
11-17-2014, 05:42 PM | #8 |
129
Rep 917
Interested in the solution. I'd remove the jb4 first just to make sure it isn't something with wiring in the DME box. Plus that's free to try. Don't forget to disconnect the battery first.
11-19-2014, 04:38 AM | #10 | |
European Editor
10589
Rep 22,992
I have to ask the obvious... your car does have fuel right>?
Maybe try disconnecting the battery for a few minutes and then retrying. Sometimes a low battery can really mess with the car's electronics. Why not borrow a buddies car to jump start yours? That would eliminate your battery. Just disconnect your neg/ground then use the known "good" battery. I'm curious as to your problem too. Dackel
11-19-2014, 05:38 AM | #11 |
193
Rep 1,181
Do you have a JB4? Minus the cranking, this exactly what happens when you reset your adaptations. The codes are a bi-product of the car not turning on.
11-19-2014, 10:56 AM | #12 | |
Rep 28
11-19-2014, 10:58 AM | #13 |
Rep 28
11-19-2014, 11:23 AM | #14 |
193
Rep 1,181
Recklessdr1ver > Did you recently install it or updated the software? On Monday, I did a firmware update and hit option 1/7 (reset adaptations). I always do this when I load new updates or get a new blend of gas. Car always goes nuts and doesn't start right away. It does exactly what yours did. Codes go nuts as well.
The only difference is that mine didn't have that long crank. It starts up right away and the RPMS go nuts. After a few tries it goes away. I clear the codes and that's it. Did it do this before the JB4? |
11-19-2014, 01:03 PM | #15 | |
Rep 28
www.e90post.com/forums/showthread.php?t=841784 , hopefully it works. |
11-19-2014, 06:57 PM | #16 |
Rep 28
Update: So I did the 1/7 option on the JB4. Result, no fix. What I did find out though is that I can get my car to start on it's own if I first push the ignition button before holding down the clutch and then pushing it again as opposed to how I normally start it which it just pushing the clutch then ignition. Next will be to take out my JB4 I guess.
11-20-2014, 07:53 PM | #17 |
129
Rep 917
That could be fuel pump related. You're priming the fuel pump by turning the ignition on before starting the car. Still could be electrical too. I'd still definitely try removing the jb4 first.
11-22-2014, 05:13 PM | #20 |
The Crowing
111
Rep 2,005
Do you have a thread on n54tech?
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
11-22-2014, 05:17 PM | #21 |
European Editor
10589
Rep 22,992
I think you need to have the throttle limitations set. When I had my SW flash tune installed here in Germany... my car did the same thing. Perhaps since you have replaced your throttle body, you now need to "code" it to the car. Or perhaps you just need to have a dealer set the throttle limits - so the DME knows what the parameters are. ?
I would take/tow the car to the dealer who told you, that your throttle body was bad and have them see what's going on. I bet you could even have BMW assist come and try to "fix" your car at your house. Might be work calling them up. Dackel
11-22-2014, 06:20 PM | #22 |
129
Rep 917
At least now that the jb4 is out your dealer won't blame that for the problem if you take the car in. I was hoping it would be the wiring with that. The throttle body coding suggestion is interesting. Makes sense. The throttle body vacuum line is in good shape at both ends?
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
