11-12-2014, 01:35 PM | #1 |
99
Rep 566
Diverter Valves Volume Increased with Intercooler
Since changing to an aftermarket intercooler I noticed the stock diverter valves are noticeably louder when coming off the throttle after heavy load. I also have DCI for intake but didn't notice the volume change until after the intercooler. The intercooler is a Dinan intercooler. Anyone else notice this? My assumption is the boost transients are higher with a more efficient intercooler so theres more presssure at the diverter valves under high load??
11-12-2014, 05:33 PM | #2 |
340
Rep 1,293
I didn't notice a difference at all. Do you hear it under load, or only when you come off throttle? If you hear it under load, I would check to see if you have a leak somewhere.
11-12-2014, 06:51 PM | #3 |
99
Rep 566
I hear it only when I come off throttle after heavy load. For example 6k shift or letting off the gas in the higher RPM range. It sounds like a blow off valve.
11-13-2014, 10:07 AM | #6 |
61
Rep 722
I got the same from my VRSF Stepped 5" but i did the charge pipe at the same time so I'm not sure which one made the diverters more pronounce but they definetly got louder aslo.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
11-14-2014, 01:55 AM | #8 |
European Editor
10589
Rep 22,992
A friend of mine told me that when he changed to a larger FMIC, he engine intake noise changed. He said it sounded more aggressive. He really did not expect any change, but the engine sound did change. I never seen anyone else talk about this. ?
Dack
11-14-2014, 08:04 AM | #9 |
1397
Rep 777
11-14-2014, 08:48 AM | #10 |
61
Rep 722
My intake sound became much more audible with the FMIC and Charge Pipe upgrade that is for sure and in a good way! You can actually hear the turbos spooling up top now
11-14-2014, 11:56 AM | #11 |
99
Rep 566
11-14-2014, 01:10 PM | #13 |
61
Rep 722
+1
