11-11-2014, 03:17 PM | #1 |
115
Rep 1,470
Parking Brake Cable after subframe bushing install
So I obviously didn't get something right. I dropped the subframe and did all the bushings and put on a RD sway bar. To do all that I had to remove the metal clips from the back of the hubs as they hold the parking brake cable in place on both sides. I reinstalled the cable ends exactly like they were yet I have basically zero tension on my parking brake handle now. It does nothing. I obviously missed something stupid. What did I miss?
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
11-12-2014, 05:16 PM | #3 |
5287
Rep 10,682
If that does not work and assuming the cable is properly installed, you may have to pull the rotor to inspect the parking brake. It is possible the end came out of its holding place while the tension was off.
How was the subframe and diff bushing job? I will be doing it soon, with AKG bushings. |
11-12-2014, 08:15 PM | #4 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
IIRC, you have to remove the rotor and the shoes to wiggle out the actuator arm that the cable attaches to. If you didn't remove the rotor then its likely that you didn't seat the actuator correctly between the brake shoes.
Or...if you removed the cables from the ebrake handle then you will need to need to tighten up the 2 adjustment nuts under the ebrake boot.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
11-12-2014, 08:20 PM | #5 |
115
Rep 1,470
Removed rotors and have cable properly attached in mechanism for shoes. Did not disconnect anything on other end of cables under handle.
11-13-2014, 12:26 PM | #6 |
115
Rep 1,470
Just had to pop the tension on the spring under the handle while lifting the handle. All good now.
