11-05-2014, 02:27 PM | #1 |
Essayons
44
Rep 424
Oil Temp
I have the BMS oil bypass valve and the weather is getting cooler. What temp is too cold for a FBO 135i? I have another car that I usually daily drive but I still take the 1er out for some fun nights and track/autocross events. Is it bad to drive the car with oil temps around 190-210 when not spirited driving? I change the oil every 7500 miles.
/ 135i - M-Sport / 6-Speed / BMW Performance Exhaust / BMS Intake / JB4 Stage 2 ISO + Flex Fuel Wires / BMS 3.5in Down Pipe / CP-E Charge Pipe / Walbro 255 in-line fuel pump / BMS H8 AE / BMS SSK / APEX EC-7's with Nitto NT05's / COBB Tuning Sport Springs / Koni Yellows / Wagner Evo 1 / Blacklines / iCarbon Rear Diffuser / BMW Performance shift knob/boot / BMW Performance Steering Wheel /
11-05-2014, 03:16 PM | #2 |
29
Rep 414
190-210 isn't too bad that's what my car runs at right now in this cold ass weather , pretty sure it's just fine. Cold starts in the morning are when you should be careful to drive your car easy until it hits 160 and the jb4 flashes at you.
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines.] |
11-05-2014, 03:25 PM | #3 |
aiming for 450.....
304
Rep 2,910
You should be good and have no issues.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
11-05-2014, 04:25 PM | #4 |
4338
Rep 6,196
I would want the oil to get hot enough to boil off the water in it. Combustion process creates quite a bit of water, and it gets into the oil. One of the features of engine oil is its ability to hold moisture suspended in it. You want to be able to get that water out. That would be 100 C, or 212 F.
11-05-2014, 05:25 PM | #5 |
Essayons
44
Rep 424
It gets up there for a bit while sitting in traffic. but once I start moving again it drops back down.
