11-03-2014, 11:31 AM | #1 |
21
Rep 86
Looking for drivers with the following mods, e85, CAI, intake spacer
Hi,
Looking for feedback on drivers using e85 with the aFe Throttle Body Spacer and an Injen Air Intake System. Similar items are okay as long as listed. Trying to figure out the following mods allow for e85 to run smoother, especially on cold start and of course WOT. I am running a drop in aFe air filter with a tank filled 60-85% e85 and the PPK stage 1. Rough cold start, and sometimes slight laggy at WOT. |
11-03-2014, 11:56 AM | #2 |
Rep 112
Drives: 2011 135I ManTransmission
You need to be running tune (jb,cobb) to accomodate running e85. PPK (if thats all your running) will not adjust for fuel mixture when you start running e85.
11-03-2014, 12:02 PM | #3 | |
21
Rep 86
More curious if anyone is running those breathing mods with e85 and are seeing decent mixture results. |
11-03-2014, 12:17 PM | #4 | |
61
Rep 722
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
11-03-2014, 12:28 PM | #5 | |
1Addict
3234
Rep 7,894
panel filter is fine. intake spacer is probably an expensive paperweight. On the tune, your car is not accounting for the fuel mixture. You need a: piggyback unit that can accommodate the e85, a flash that was either written for a certain % mixture, or a custom flash for whatever you want to run. Your biggest problem though is the pump.
11-03-2014, 03:38 PM | #6 | |
21
Rep 86
This would work? $210 http://www.fuel-it.biz/e-series-stag...grade-options/ |
11-03-2014, 04:02 PM | #7 |
1Addict
3234
Rep 7,894
Since it sounds like your lpfp may be failing, and I'd expect it to be if you've been punishing it with 60-85% ethanol for a year; I would go ahead and swap out to his stage 2 pump.
http://www.fuel-it.biz/e-series-stag...grade-options/ You're going to need to flash your car to an E85 compatible map as well, so start thinking about Cobb if you don't want to go back to using the JB4.
11-04-2014, 09:01 AM | #8 |
82
Rep 847
Drives: 2011 135i M Sport
Get a Walbro Inline and a tune, not gonna get much out of e85 if you are not tuning for it..
BMW Performance Kidney Grille, CF Lip Spoiler, CF Diffusser, Blackline LCI Tailights, Magnaflow Full Exhaust, BMS Intake, Jb4 w/ E85, Meth Injection, BMS DP, VRSF 5" Intercooler, CP-E Charge Pipe, KW CS Coilover, M3 Subframe Bushings, VMR VB3 Wheels, Stage 2 Fuel Pump, M3 Control Arms, Dinan Camber Plates, Pure Stage 2.
11-04-2014, 09:58 AM | #9 |
61
Rep 722
+1
