10-29-2014, 06:40 PM | #1 |
BimmerPost Supporting Vendor
2917
Rep 21,727
▀▄ eas | F8X M3/M4 Brembo GT Big Brake Now Available
Brembo-GT Big Brake Kit Designed and tested specifically for track day enthusiasts and for drivers who demand the utmost performance from their cars, Brembo GT Big Brake Kits offer superlative performance for both normal driving and demanding track day sessions. Brembo kits consist of cross-drilled or slotted ventilated, integral or composite discs and aluminium calipers with 4, 6 or 8 pistons; a complete set of high performance pads; metal-braided hoses and high quality hardware. Using radial-mounted fixed calipers together with oversized discs gives the system greater braking torque and superior thermal capacity. The result is a braking action that is noticeably more immediate and decisive even in normal road usage, and is extraordinarily powerful and consistent under the repeated loads of track use. Fixed calipers improve the durability and efficiency of the system: the opposed multiple pistons act on the pads with more precision, due to the smaller piston diameter and the reduced pressure exerted on each individual piston, while the greater overall surface area between the pads and pistons results in more uniform friction surface wear. The superlative stiffness of the calipers and the metal braided hoses reduce brake fluid absorption. The result is improved, more stable brake pedal pressure, making it possible to modulate braking force more precisely and enhancing pedal feel. Featuring a hat in aluminium alloy, the oversized floating disc system reduces unsprung mass (for improved handling) and thermal stress. The mounting system is engineered to permit a greater degree of both radial and axial float. This characteristic, together with the greater dimensions of the braking rotor surface, improves the dispersion of the heat generated by the repeated, intense thermal stress that the discs are subjected to, for consistent braking performance and pedal feel even after numerous laps on the track. With a combination of painted calipers (available in red, yellow, black or silver) flaunting the Brembo logo, and slotted or cross-drilled discs, the Gran Turismo kit gives an unmistakably sporty, eye-catching look to the car, offering that extra special touch for drivers who want their vehicle to stand out from the crowd. Caliper colors available -Black -Yellow -Silver -Red Sizes Available -Front 405mm 6 piston -Front 380mm 6 piston -Front CCM-R 380mm 6 piston -Rear 380mm 4 piston -Rear CCM-R 360mm 4 piston Features: - Proven on-track performance - Disperses gasses, cleans pads for better bite - Reduces unsprung weight for better handling - Provides maximum braking force without the flex of sliding calipers - Reduces heat-related stress, increases brake performance and pedal feel - Aggressive pads that last longer and provide the highest level of performance Big Brake Kit Includes: - Brembo Brake Calipers with Brake Pads - Brembo Brake Discs (Cross-Drilled or Slotted) - Stainless Steel Brake Lines - Mounting Brackets & Hardware Models Supported 2015+ BMW F80 M3 2015+ BMW F82 M4 Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday/Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 10-29-2014 at 07:31 PM.. |
11-03-2014, 05:04 PM | #2 |
2917
Rep 21,727
Now Available for your F8x
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-20-2014, 06:47 PM | #3 |
2917
Rep 21,727
12-30-2014, 07:24 PM | #4 |
2917
Rep 21,727
Step up your braking with a Brembo BBK!!
