10-24-2014, 08:33 AM | #1 |
2015 X1 35i XDrive with NAV
76
Rep 659
Drives: 2015 X1 35i
Oil pressure
Does anyone know what the oil pressure is on an N54 when warm?
2015 X1 35i XDrive Ultimate, NAV & Cold Weather Package MHD, FTP Motorsports Charge Pipe, Drop in K&N |
10-24-2014, 10:21 AM | #2 |
81
Rep 1,051
Don't know your answer, but keep in mind RPM matters as well, and there is a relief/bypass valve that sets an effective maximum (typically ~80psi).
So for idle and 3000rpm there will be different values.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
10-24-2014, 04:51 PM | #3 |
76
Rep 659
Drives: 2015 X1 35i
Mine at a cold startup is shows 100 PSI on my oil gauge at an idle. After it gets to operating temp its around 40 PSI at idle. I'm using Royal Purple 5w-30. I thought maybe the gauge was off so I hooked up a mechanical gauge and it had the same reading so the gauge is correct. Below is where I have it tapped in for the sensor. That braided hose goes to the sensor thats mounted near the firewall.
I'm new to the N54 and BMW's and my past cars never had oil pressure that high, most were at 65 psi cold and 30 at an idle. So when I installed this oil pressure gauge I was surprised at these readings. One time it was at 115 PSI on a chilly day, around 40 deg in the morning.
2015 X1 35i XDrive Ultimate, NAV & Cold Weather Package MHD, FTP Motorsports Charge Pipe, Drop in K&N Last edited by BMWX1-35i; 10-24-2014 at 05:02 PM.. |
10-24-2014, 04:57 PM | #4 |
European Editor
10589
Rep 22,992
Don't you mean PSI ???
10-24-2014, 04:58 PM | #5 |
76
Rep 659
Drives: 2015 X1 35i
10-24-2014, 05:05 PM | #6 |
European Editor
10589
Rep 22,992
Ok, cool.
I ran a search on Google, found this... N54 Oil pressure - results are in! http://www.e90post.com/forums/showthread.php?t=581081
10-24-2014, 05:09 PM | #7 | |
76
Rep 659
Drives: 2015 X1 35i
10-24-2014, 05:18 PM | #8 | |
European Editor
10589
Rep 22,992
Sounds normal to me.
10-24-2014, 05:30 PM | #9 |
76
Rep 659
Drives: 2015 X1 35i
