10-22-2014, 04:05 PM | #1 |
127
Rep 316
Differential Side Bearings Part Number?
I have a 6MT E92 and the sidebearings on the differential have started to wear (due to broken diff bolts and the diff hanging, happened 3 years ago). Does anyone know where to buy the bearings and/or the part number? These are the bearings inside the differential on either side.
10-22-2014, 06:18 PM | #2 | |
115
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
10-23-2014, 10:55 AM | #4 |
Bad Lieutenant
233
Rep 3,517
These?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
10-23-2014, 04:09 PM | #5 |
115
Rep 1,470
Carrier bearing are inside the diff housing with one on each side.
10-23-2014, 04:15 PM | #6 |
127
Rep 316
I took carrier as the center bearing for the driveshaft.
Yes, I'm after bearings inside the diff on the two sides. The pic attached is from another car that shows that bearing I'm after. |
10-23-2014, 10:02 PM | #7 |
115
Rep 1,470
Pinion bearing(s) are for the pinion gear which attaches to driveshaft. You want carrier bearings.
