10-20-2014, 09:48 PM | #1 |
87
Rep 602
What other cars share our differential?
So while budgeting for a Dinan 3.45 diff for the M3 I came to find out that they no longer offer this ratio, and any back orders have been canceled. Explanation was that BMW Motorsport has dropped this gear set from their lineup. So now I will be shopping around for a used one, or one from another donor M car that shares the same diff as ours. Does anyone know if anything else in the lineup has the same rear differential as the M3? Need more torque to the road but not willing to go as radical as the 3.62. Thanks for any input.
Blue Thunder -2011 LeMans Blue e92 DCT, ZCP, European Delivery. BPM Stage II. Dinan 3.45 Rear. Borla/Encore Innovation Exhaust, LUX Angel Eyes, Forgestar F14's, Turner road armor. "Last of the V-8 Interceptors, a real piece of history..."
10-21-2014, 07:23 AM | #3 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I think an F10 M5 shares an upgraded version of the diff.
I do believe the E9X M3 diff uses a 210mm gearset. So, I think, if you can find a 3.45 from an E46 M3 or E39/60 M5...you can change out the R&P. I'm going to stuff a 4.10 R&P into my E46 M3 and take the 3.62 and see if it fits into my E90 DCT.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
10-21-2014, 10:53 AM | #4 | |
23
Rep 177
Thanks |
10-21-2014, 02:01 PM | #5 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
i want to find a 6spd e92m diff and swap it out, so bad...
10-21-2014, 02:03 PM | #6 | ||
1571
Rep 8,076
Apparently the install a total PIA. You have to get the preload and backlash correct (whatever that is) or else you'll be clunking like crazy and destroy your diff.
10-21-2014, 10:18 PM | #7 |
87
Rep 602
3.85? That would be a bit much for DCT no?
10-21-2014, 10:40 PM | #8 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
My brother had 4.10s in a e46m and it was awesome.
I had 3.15s in my 95 and the switch to a 3.38 wasn't very noticeable. I've never been anywhere near the redline in 5th. Doubt even on a track redline 6th is pretty fast/hi mph. I think it would be a fun mod. |
10-21-2014, 11:05 PM | #9 |
115
Rep 1,470
To properly set backlash and pattern, you need a set of setup carrier bearings. You need a tiny torque wrench to set bearing preload. You need all the seals, shims, and the pinion crush sleeve if so equipped. I have done it on Toyota 8.4" and Dana 44 for locking diffs. You need a dial indicator and special grease to check the teeth. This is not a one banana job. Setting up gears is as much art as skill. Even with my background, I would pull my diff and have it set up professionally with a better LSD but probably no R&P swap since I have DCT.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
