      10-18-2014, 12:54 PM   #1
wrxified
14
Drives: 2006 BMW M5
Before I go ballistic on this Cobb charge pipe.....
Trying to install the Cobb Charge Pipe on an 2011 N55 135i. Cobb part # is 7B2210.
Will someone tell me if I'm missing something. This isn't rocket science so I can't imagine it's anything other than the fact that the fitment of this pipe just blows.
Stock charge pipe blew up yesterday. Given the fact that I didn't want to have to worry about when a second BMW stock pipe would fail, and I was in a pinch to get this back up and running by tomorrow, I ordered the Cobb charge pipe now thinking I'd just move on and put this all behind me.
So in a hurry I called Cobb. Cody from customer care was awesome and quickly worked with the warehouse crew to work out a way to get me a replacement pipe with overnight Saturday delivery. I gotta mention this because I've worked with Cobb in the past for my STi and MS3. He was awesome and did the whole thing in minutes. To top it off he even took the box with him to drop it off at Fedex since their guy had already made the stop 2 hours earlier. Not many companies do this type of thing anymore. You order their product and they do what they can to manage the backorder and get it out to you when it works for them.
The pipe shows up as agreed this morning at 10am. So I start digging in thinking this should be a 15 to 20 minute job. After all, I already have the stock pipe off. Just need to pop it in place, tighten everything down and I'm back to normal. Not so fast. It took all but a few minutes to realize this doesn't seem right. So far I'm not comfortable with how this pipe fit. Problem is, it simply doesn't fit without putting incredible stress on the throttle body, the pipe itself, and resting with and insane amount of pressure on the bracket that holds the radiator overfill reservoir. It's almost as if this is designed for a 335i or something. Some car with more space in the engine bay. I mean, I can actually muscle this pipe into place by brute force, but it without a doubt is placing an incredible amount of pressure on the throttle body flange. It takes a herculean effort to rotate it into place and I'd say it probably has over a hundred lbs of pressure resting against the bracket.
Has anyone else installed the Cobb and did they feel half way through the install that they wanted to stop, pull the pipe out, throw it to the ground, and start a violent ghetto stomp in their garage on the unit? I'm half joking, half serious. Who has time for this shit?
I even removed the radiator reservoir bracket that the charge pipe is resting against to see if it fit that way. Barely and it's compressing the radiator lines to about half their normal size.
So I have a few choices at this point.
  1. Just accept the fact that it fits like shit, rests against the radiator reservoir bracket on the side of the engine bay and hope that it doesn't rattle non-stop every time I press the gas and the engine shifts under load. That along with keeping my fingers crossed that it doesn't create an issue down the road with the added strain on the throttle body flange or lose boost pressure because all of the pressure on the o-ring inside the charge pipe flange is on one side of the pipe.
  2. I can pay to ship it back and hope to plead my case that this is unacceptable and maybe get my money back for the pipe itself. A little worried as it's all scratched to hell trying to get it in place. I'm fairly sure I'd just be out the $50 shipping to me and $10 shipping back.
  3. Someone can point out my error and let me in on a secret that I may have missed in the instructions on Cobb's site.
  4. Just proceed with the ghetto stomp in the garage to help blow off some steam and frustration.
If you can't tell I'm somewhat frustrated. The overnight shipment was costly as would be expected. Hoping I'm actually missing something and someone can point out my error so I can move on.
      10-18-2014, 01:05 PM   #2
wrxified
14
Drives: 2006 BMW M5
Doing a google search on the Cobb part number I notice it's a design for all N55 powered cars. That's gotta be part of the issue. I bet if I was doing this on a 335i it wouldn't be an issue.
Applications:
USDM : 135i 2011-2012
USDM : 135is 2013
USDM : 335i, xi, i, xDrive 2011
EDM : 135i 2010-2011
      10-18-2014, 01:22 PM   #3
Freon
Drives: 2009 135i
Can you get the front end of the pipe into the silicone hose and snap another picture?
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
      10-18-2014, 03:45 PM   #4
wrxified
14
Drives: 2006 BMW M5
Yeah. I'll shoot some pics later. I found a way to rig it and get it installed. Basically entailed drilling new holes on the reservoir bracket to move it in.
Back up and running which is a good thing. The pipe definitely isn't ideal and I'll be sharing my thoughts and feedback with Cobb. Without modifying the bracket the banging and clattering would've been relentless. That and the seal between the throttle body and charge pipe would be compromised eventually. I really get the impression that the testing started for this part in another chassis that shared the N55. Some monkey wrestled it into place on the 135i then gave the thumbs up to their boss to list it for our models.
      10-18-2014, 11:39 PM   #5
UR25IO
UR25IO's Avatar
Australia
97
Drives: 2011 BMW 135i M-SPORT DCT
That look about right, Ive just Installed cobb C/pipe and FMIC (now that was hard work)
Try to tuck the bottom hose underneath and push the other hose across as far as possible.
I will post some pic in a couple hours
      10-19-2014, 01:22 AM   #6
UR25IO
UR25IO's Avatar
Australia
97
heres my set up
      10-19-2014, 08:35 AM   #7
Devins 1SER135
Drives: 1 Series
      10-19-2014, 09:46 AM   #8
jreynolds
Drives: 335
you've gotta get the lower coupler in for the correct fitment.
      10-19-2014, 11:26 AM   #9
wrxified
14
Drives: 2006 BMW M5
Understood. I had the coupler fully attached prior to this picture and it didn't fit. I started to pull it out and thought as I was doing it to take a picture at the last minute.
Here is how it ended up after the re-drilling the holes to move the radiator overfill brace in towards the fender. You can sort of see the gap in one of the pictures after moving the bracket 3/8". Without the bracket moved the charge pipe sat firmly against it with a lot of pressure.
      10-19-2014, 06:40 PM   #10
Eyeman
Eyeman's Avatar
121
Drives: 2008 135 blk, blk, step
Here's how my ER pipe looked when installed just to give you a comparison pic. I had already moved my brake fluid reservoir when I installed my Injen intake.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      10-19-2014, 08:12 PM   #11
trainerjon
trainerjon's Avatar
Drives: 2011 BMW 135i M package
Cobb CP sure looks nice... hope you figure this out
'11 135i M-Sport DCT, M3 RSFB, PPK, CP, BMS intake, Agency Power Axle Back, VRSF 5.5" FMIC, FSB, M3/M1 Front + Rear Control Arms, Ground Control Coilovers, Ground Control Camber Plates, E92 M3 Front Seats, VMR 701's Squared 255's, E92 M3 Steering Rack - Daily Driven, Occasionally Tracked - 157k miles <SOLD> >2021 HS M2C Manual
      10-20-2014, 02:09 AM   #12
Robmaster
Robmaster's Avatar
Switzerland
151
Drives: 2010 E82 135, 2005 E87 130i
is this problem at all CP's for the N55??
in the BMW ETK, there is no different part-no. for the E82/88 CP. It's the same as the E9x CP.
      10-20-2014, 07:14 PM   #13
loesch
loesch's Avatar
Drives: 2011 BMW 135i M Sport
I had a cp-e charge pipe and it fit like that too. Needless to say it's gathering dust in my basement. Running ETS now.
      10-20-2014, 10:27 PM   #14
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I can tell you I didn't have this issue wit the er charge pipe. Have you contacted Cobb about the fitment issue? I would not settle for an item that doesn't seem to fit properly. I can show you pics of the er charge pipe on an n55 If it helps.
      01-19-2016, 08:39 PM   #15
ThatKidDavid
Member
ThatKidDavid's Avatar
Drives: 2011 135i
Sorry to revive an old thread but it seems like multiple ppl are having these fitment problems with the Cobb CP. I was wondering what the easiest solution would be to get the CP to fit? I'm in the market for a CP and would like to go Cobb cuz of price/finish/manufacturer but if install isn't a simple bolt on then I'd consider others. Please share your input!
      01-19-2016, 10:52 PM   #16
tglazed
46
Drives: 135i
Just remove your throttle body (4 bolts) and it will slip right on. The tolerance for the Cobb chargepipe is just really tight, where other are a bit looser. You don't need to remove the bolts all the way although I did. You can just losses them enough to tilt the throttle body up and the Cobb chargepipe will slip right on.
      01-20-2016, 12:23 PM   #17
katsooba
katsooba's Avatar
85
Drives: bmw 135i
Hi,
judging by the first picture the op has posted, it doesn't seem that the CP is fully latched on to the throttle body, after you move the o-ring from the stock CP, dab your finger in some motor oil and lube the o-ring, after you do you
stand firmly next to the fender, and using both hands, grip that sucker and wiggle it onto the throttle body until you see the C-clip groove in the TB through the CP.
i have the CP-E charge pipe, had the same fitment problem until it went fully onto the TB.
one hand install is a b1tch, grab that sucker and wiggle it
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
      01-25-2016, 08:51 AM   #18
weeeee
40
Drives: 2011 135i
ER install was a bitch to muscle in place but it worked in the end.
      01-26-2016, 10:49 AM   #19
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
For the record we had dozens of customers we know about have problems with the Cobb CP fitment.
Stick with the ER if you don't want any fitment problems.
I know the Cobb price is very tempting but in this case, you get what you pay for.
      02-03-2016, 09:40 AM   #20
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
I'd return the Cobb & go with a reliable/proven CP, they should absolutely provide you with a return label and you shouldn't lose money on a product that doesn't fit well.
      02-12-2016, 10:59 PM   #21
Reapur
17
Drives: 2009 135i
You kids dont belong under the hood of a car.....
Power steering reservoir mistaken for an expansion tank and brake fluid reservoir ?
damn never seen such sillyness
bobowar1353479.00
      02-14-2016, 04:23 PM   #22
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
LOL. Looks like the Cobb unit has a manufacturing issue. The pipe is just too long.
I bought the VRSF unit almost 18 months ago. Fit like OE, and I haven't had any issues out of it yet. Money spent doesn't always equal a better product. Just saying.
2014 M5 6MT
